Author Topic: D code - Starter Cable bracket picture  (Read 12679 times)
Offline john_simms
« on: February 25, 2012, 02:14:07 PM »
Does anyone have a picture that shows the correct positioning of the two clamps that mount to the motor mount bolts and hold the starter cable in position?  1964 1/2, D-code V-8.
Thanks.
« Last Edit: May 17, 2020, 11:40:34 PM by J_Speegle »
Re: Starter Cable bracket picture
« Reply #1 on: February 25, 2012, 03:35:35 PM »
The bracket (maybe two) are between the bolt and the mount, angled out and down a bit for the cable to clear the bracket and manifold. If you have a heat shield, it goes between the mount and the engine.
« Reply #2 on: February 25, 2012, 07:35:12 PM »
First question is always (if you don't provide it ) is;
John when and where was your car built? (or a guess from the door tag info ;)
« Reply #3 on: February 25, 2012, 07:37:24 PM »
Difficult to find a good picture with that big generator in the way but we'll try
« Reply #4 on: February 25, 2012, 08:05:44 PM »
Excuses, excuses!   8) ;D
« Reply #5 on: February 25, 2012, 08:22:43 PM »
An electronic surplus store item?  ;)
« Reply #6 on: February 25, 2012, 08:51:20 PM »
Open to speculation I suppose.  The clamp is unique as it has a lock tab to hold the ends together.
Offline kutzoh
  • Gold Level Subscriber
« Reply #7 on: February 25, 2012, 08:52:16 PM »
John-
   Is it these clamps:
http://www.virginiaclassicmustang.com/65-73-STARTER-CABLE-BRACKETS-PAIR-FITS-260-289-302-351W-390-428CJ-P1154C1063.aspx
If so, I'd like to see a picture also. I have a set but haven't installed them as I'm not sure if they're correct to use on my coupe.
Greg
« Reply #8 on: February 25, 2012, 08:53:25 PM »
John-
   Is it these clamps:
Greg
Guess I mis-read the original post...  :(
« Reply #9 on: February 25, 2012, 08:55:56 PM »
Beat me too it - but I did write we'll try ......... and you can through making good on my statement ;)
Its all about teamwork !!
Offline kutzoh
« Reply #10 on: February 25, 2012, 08:59:03 PM »
Since John and I both have D-codes, were these originally used from the factory?
Greg
Offline john_simms
« Reply #11 on: February 25, 2012, 09:55:32 PM »
John-
   Is it these clamps:
Greg
Yes those are the clamps I was referring to.  My car has two, but they've always just hung off of the starter cable and were never bolted to anything.  There is also a woven fiber sleeve over the starter wire that fits in there someplace too.  It is much like the sleeve that is over the oil pressure sensor wire, only much larger in diameter.
Offline john_simms
« Reply #12 on: February 25, 2012, 09:57:33 PM »
I actually need one of those too.  Someone was making those in their garage and getting $35 dollars a pop for them.  I can't remember if I saw them here or over on the Vintage Ford Mustang website.
« Last Edit: February 25, 2012, 10:09:57 PM by john_simms »
« Reply #13 on: February 25, 2012, 10:01:24 PM »
I actually need one of those too.  Someone was making those in there garage and getting $35 dollars a pop for them.  I can't remember if I saw them here or over on the Vintage Ford Mustang website.
Think they were on ebay a while back.
« Reply #14 on: February 25, 2012, 10:17:31 PM »
i think these folks were making them
 http://buckeyeclassiccarrestoration.com/Buckeye_Classic_Car_Restoration/Home.html
