Author Topic: 1969 Rear drum blackout  (Read 17455 times)
Offline ASSET90
« on: February 16, 2012, 02:53:52 PM »
Does anyone have photos of 69 rear drums so I can see the brushed on blackout? Any help will be appreciated. Thanks
Re: 1969 Rear drum blackout
« Reply #1 on: February 16, 2012, 09:35:34 PM »
Here is a reproduced effort
Here is an original (67 example) the rust shows up as orange - must have been the camera settings
Offline john_simms
« Reply #2 on: February 17, 2012, 12:06:09 AM »
You guys strive for perfection that I can only dream about!  Great job, hat's off to you!
« Reply #3 on: February 17, 2012, 08:15:27 PM »
You guys strive for perfection that I can only dream about! ...
Oh you can have it if you want it ;) We're here for help and support
As a NOTE - The blackout appears to be dependent on what wheels were ordered - typically styled steel wheels received this in 69.
« Last Edit: December 18, 2012, 08:05:29 PM by J_Speegle »
Offline ASSET90
« Reply #4 on: February 17, 2012, 09:33:59 PM »
Thanks Jeff, That is exactly what I was looking for!
Offline Anghelrestorations
    • Anghel Restorations
« Reply #5 on: February 18, 2012, 01:41:18 PM »
The sloppy application of the blackout looks good....on this one I did a few years ago it was probably not sloppy enough.  You also could/should machine the edge of the drum and the groove if you want it to look correct.  The edge of the drum especially stands out nice when looking on the underside when everything is assembled again.
Marcus Anghel
www.anghelrestorations.com
« Reply #6 on: February 18, 2012, 03:13:20 PM »
As Marcus relates the blackout is too nice compared to assemblyline however the The groove detail and edge detail is spot on. Nice job!
Offline app01
« Reply #7 on: December 18, 2012, 06:41:14 PM »
Was this same blackout  also done in 1970?  (car is a May 70 Dearborn build Boss 2)
Currently own:
1962 Corvette 340hp
Previously Owned:
1970 Mach 1 (my 2nd car)
1989 GT
MCA #62598
www.PalmieriConcepts.com
« Reply #8 on: December 18, 2012, 08:04:34 PM »
Guess we should have made it clear from the beginning
The blackout appears to be dependent on what wheels were ordered - typically styled steel wheels received this. Which for you (70 owner) would mean (as I understand it) magnums
Offline app01
« Reply #9 on: December 19, 2012, 08:20:25 AM »
Thank you.. makes perfect sense.
Currently own:
1962 Corvette 340hp
Previously Owned:
1989 GT
MCA #62598
Offline TLea
« Reply #10 on: December 19, 2012, 06:29:15 PM »
Whats interesting to me is that those features are not always machined. You will find drums that the groove is actually cast into the drum. Those also seem to have a cast non machined edge as well
« Reply #11 on: December 20, 2012, 11:53:52 AM »
2 vendors
« Reply #12 on: December 20, 2012, 02:02:48 PM »
2 vendors
OK which two and were rear axles assemblies shiped with ot without brake drums?
« Reply #13 on: December 21, 2012, 11:24:29 AM »
The whole rear assembly was all together with drums on & green clips holding them & orange plastic holder keeping brake cables together on complete assembly. On the Dearborn cars I worked on I have seen KH on 1 side & bendix on other & hardware different on brake cylinders between the 2 with flat bolts on 1 & sunken head bolts on the other & both have different ink stamps date type marks & both types rubber adjusting plugs. I see more drums without extra hole type than other version on Dearborn cars.  Also later they started stamping date on bottom outside backing plates in the metal.
Offline Toploader
« Reply #14 on: December 21, 2012, 01:29:56 PM »
What was the purpose of machining the edge after the blackout application and what was the function of the groove?
76A-Y-D2-13H-72-6-6
