Author Topic: dimer switch cap  (Read 4057 times)
Offline smp
dimer switch cap
« on: February 13, 2012, 02:22:40 PM »
Hi I have a late built 66 convertible Did the car come with the black rubber cap over the dimmer switch.My carpet has the black ring around the hole.Will the cap fit with that ring in place.Does any one have some pics. thanks.
dearborn built 66 convertible- 289 auto- Tahoe turquoise aqua- white intier decor group - build date 16f.
Re: dimmer switch cap
« Reply #1 on: February 13, 2012, 02:39:24 PM »
Convertibles usually had the black rubber cap on the dimmer switch.  There should be no plastic grommet in the carpet though.
« Last Edit: February 13, 2012, 07:07:33 PM by carlite65 »
Offline smp
« Reply #2 on: February 13, 2012, 05:01:35 PM »
Thanks caspian65.My carpet looks to be the orginal.so just coupes and fastbacks used the grommet.Will the cap fit useing the grommet.
« Last Edit: February 13, 2012, 07:07:52 PM by carlite65 »
Offline tomtri66
  • Bronze Level Subscriber
« Reply #3 on: February 13, 2012, 05:13:30 PM »
According to MCA rules the grommet is not correct for any body style.
« Last Edit: February 13, 2012, 07:08:10 PM by carlite65 »
C/O    762
4        A20     6T07T194XXX
65A       Y        22
« Reply #4 on: February 13, 2012, 06:55:34 PM »
The plastic grommet was never used on factory carpet.
« Last Edit: February 13, 2012, 07:08:34 PM by carlite65 »
Offline 69RavenConv
  • Owner since '74
Re: dimer switch cap
« Reply #5 on: February 13, 2012, 07:49:09 PM »
Can anyone explain the rationale behind putting the cap on convertibles but no other body style?
I've read lots of speculation but no definitive answer. Just curious...
Phil
'69 Convertible - Dearborn June 4, 1969 - Raven Black & Red - 302-2V
« Reply #6 on: February 14, 2012, 12:02:13 AM »
So your foot willn't slip off the dimmer switch while driving in the rain with the top down and wanting the high beams on :D
« Reply #7 on: February 14, 2012, 01:26:04 AM »
Convertibles have inner rocker panels.  The dimmer switch is a little harder to reach than in a coupe/fastback.
Offline tomtri66
« Reply #8 on: February 14, 2012, 09:10:10 AM »
So wait, what your saying is that unless you have a convertible, the dimmer switch should just be bare metal?  My coupe has one and has had one since I bought it.  Find it hard to believe a PO added it but I suppose it could be true. If I remember correctly the 65 I owned years ago had one as well ???
C/O    762
4        A20     6T07T194XXX
65A       Y        22
« Reply #9 on: February 14, 2012, 10:31:20 AM »
Yes, only convertibles were supposed to get the rubber dimmer switch cap.  I'm sure some coupes/fastbacks might have slipped through with one.  There is even a mention of it in Ford documentation somewhere, maybe the MPC or assembly manuals.
Offline 69RavenConv
  • Owner since '74
« Reply #10 on: February 14, 2012, 10:43:04 AM »
That makes sense to me, although I like Bob's explanation (below) better. Especially when driving barefoot at the beach. ;D
Quote
Phil
Offline smp
« Reply #11 on: February 14, 2012, 01:03:50 PM »
Ok then a carpet with the gromment around the dimmer switch hole is that a reproduction carpet.can it be removed to use the cap.
« Reply #12 on: February 14, 2012, 02:39:24 PM »
Bob gaines is serious with his answer as that is why the rubber boot is on converts. After having 2 verts with the boot on dimmer switch i looked up ford part # & says 76 convertibles use so i looked at switch location on floorboard & the inner convertible rail blocked your shoe from reaching over by kickpanel to find dimmer switch. It is harder to reach switch on 4-speeds because of clutch pedal in the way verses auto.
« Reply #13 on: February 14, 2012, 03:58:07 PM »
Annnnnnd Ed likes to drive in the rain with the top down flashing his high beams at on coming traffic  :D  :D
« Reply #14 on: February 14, 2012, 08:05:33 PM »
Sure, the grommet can be removed.  Hopefully the hole wasn't cut real big.
