Author Topic: Chrome hood molding 69 different then 70?  (Read 8911 times)
Offline SCJSTU
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
Offline jmlay
Re: Chrome hood molding 69 different then 70?
« Reply #1 on: December 18, 2009, 09:08:25 PM »
Yes, 69 & 70 are different. 70 had a reinforcement that fir behind the molding.
Mike
Mike
1969 Mach1 428 CJ Ram Air
San Jose
Scheduled Build: 1/2/1969
Actual Build: 1/3/1969
Released: 1/8/1969
Offline BillEBobb
« Reply #2 on: December 19, 2009, 11:46:53 PM »
Yes, and the retaining nuts are different too.  AMK carries the correct nuts for both years.
Offline cobrajetchris
« Reply #3 on: December 20, 2009, 03:06:57 PM »
The 69 and 70 mustang hood moldings are different and have seperate part #s c9zz and d0zz for the 70 model. The actual molding is different due to the grille trim differences between 69 and 70. Both parts will bolt up to the hood since the hood is the same however the trim will not match up. As for as the retainer part that is behind the molding I am not certain if this was used on both years or not as I have heard it was a 70 only part but I have a original paint 69 hood with the 69 flat black paint and the hood pin style retainers and this hood had the retainer. This may have been a part added later in the 69 production, maybe someone can clarify that.
CHRIS KNOBBE
Offline 69grandecj
« Reply #4 on: December 26, 2009, 11:57:05 PM »
I believe the '69 molding has a more "peak" than the '70 version to match the outer moldings.
MCA # 24108
MCA Gold Card Judge 3rd Generation
MCA Certified Judge 69-70
1969 Mustang Grande 428 CJ
1969 Mustang SportsRoof
1989 Mustang GT Convertible 22K miles
Offline McKeever
« Reply #5 on: December 30, 2009, 09:14:50 PM »
Actually,
I think you will find the 69 and 70 hoods Are different. Subtle, but different.
Mark McKeever
January, '70 Dearborn BOSS 302
0F02G154740
Owned since March 1974
« Reply #6 on: December 30, 2009, 09:23:43 PM »
The only difference between a 69 and 70 hood to my knowledge is the inner structure has larger holes to accommodate the larger twist lock style hood locks on the 70 MACH 1.
I believe FORD only sold the 70 style as a service part after the 70 production began. I used to buy hoods 25 years ago from FORD and they had the D0ZZ part # which is for a 70 even if you ordered it as a 69. As for a outside appearance and dimension they are identical.
CHRIS KNOBBE
Offline 69grandecj
« Reply #7 on: December 31, 2009, 01:23:10 AM »
+1
MCA # 24108
Offline BillEBobb
« Reply #8 on: December 31, 2009, 04:30:15 PM »
This is absolutely correct. The 69's had a more elliptical shaped hole and the 70s necessitated a larger round hole to accommodate the twist-style hood lock.
Offline McKeever
« Reply #9 on: January 02, 2010, 09:20:01 PM »
Those were the differences I was referring to, as I said subtle.
The indentation for the Air Cleaner is also different on a '70. It has a dimple on the right (passenger side) the '69 does not.
« Last Edit: January 02, 2010, 09:26:29 PM by McKeever »
Mark McKeever
0F02G154740
Offline SCJSTU
« Reply #10 on: January 06, 2010, 09:45:57 AM »
well there are more differences then you think.........
1) the front corners on the underside are slightly diff.........see pic
2)the area for hood pins as mentioned
3) next to the hood latch there was an indent on the bracing the hood latch bolts to.....seems there was a change maybe Jan 1970 on this?
I will post a pic when my other computer gets back from the shop if Jeff or someone does not post before
also hoods have a date code on drivers edge on underside
« Last Edit: January 06, 2010, 10:14:40 AM by SCJSTU »
