Author Topic: Flange Bushing For Fastback Deck Lid  (Read 4398 times)
Offline MWM
« on: February 06, 2012, 08:49:53 PM »
A while back there was a discussion thread regarding the plastic sleeve that goes through the hinge support on the passenger side to support the torsion rod on the fastback deck lid.  I believe the part is called a plastic flange bushing with an ID of 3/8". Since I was not able to locate one that look reasonably close in appearance to disintegrated one that I pulled out, I had to result to other means. I recently went to ACE Hardware (yes, Ace is the place!) and found nylon washers in the correct color, thickness and diameter.  I then found some plastic tubing, cut to length and then glued together.  When assembled and inserted onto the car, it's hard to tell from the outside that it's not original - except that it looks new.  I hope this may help someone else in the future.
Re: Flange Bushing For Fastback Deck Lid
« Reply #1 on: February 06, 2012, 09:46:38 PM »
Cool, thanks for sharing.  Remember that the bushing would have paint on it since it was installed before the car was sprayed.
Offline MWM
« Reply #2 on: February 06, 2012, 10:07:51 PM »
Oops!  Good catch Charles.  I'll add a little paint to help blend in!
Thank you!
« Reply #3 on: February 06, 2012, 10:13:54 PM »
I think I know what part you're talking about, but...can you provide a picture?
« Reply #4 on: February 06, 2012, 11:10:51 PM »
Pictures????  ;)
« Last Edit: September 23, 2017, 06:50:13 PM by J_Speegle »
« Reply #5 on: February 07, 2012, 12:22:33 AM »
This is the type of item that I was referring to, it needs to be added to the "Why Doesn't Somebody - " posts. I haven't found any reference to this part but it may be part of the hinge assembly, eg, came with the hinge.
« Reply #6 on: February 07, 2012, 10:32:29 PM »
I don't recall that flange on my 66 (just looked---mine is missing).  I thought you were referring to a retaining "axle clip" that looked more like a hat that prevented the torsion bar from being removed from the lever arm.  That little piece is not reproduced and is a bugger to find!
« Last Edit: February 07, 2012, 10:36:06 PM by midlife »
Offline ChrisV289
« Reply #7 on: February 08, 2012, 07:58:08 AM »
I thought AMK had something similar in their catalog?
2009 V6 Mustang Coupe
Offline Brant
« Reply #8 on: February 08, 2012, 01:27:00 PM »
Not all 66 fastbacks had this bushing.  Some cars appear to have a smaller hole in the hinge and would not even accommodate a bushing.  I have observed this change happening in late '65, but I am always interested in more evidence.
November 1965 San Jose car
June 1965 San Jose Car
« Reply #9 on: February 08, 2012, 06:27:41 PM »
My San Jose May 65 build Fastback - no bushing; my San Jose Oct 65 build Fastback - no bushing; 6S1232 Feb 66 build - no bushing. I can't answer if the hinges on my 65 or the Shelby are factory supplied without the bushing.
Offline ChrisV289
« Reply #10 on: February 08, 2012, 08:17:59 PM »
Here is Oct 1964 SJ
« Last Edit: September 24, 2017, 12:27:16 AM by ChrisV289 »
« Reply #11 on: February 08, 2012, 10:54:29 PM »
My car, May 65, does not have a bushing.  If it did have one it was a mighty tight fit.  Sheet metal date stamp in that corner is 4 20 D2.  Looks like quite a parlor trick to get the rod in there as well.  Brian
« Reply #12 on: February 09, 2012, 10:26:30 PM »
The flange may well have been installed first on the torsion rod, before it was installed in the deck lid, then slid into place.  Whaddya think?
« Reply #13 on: February 10, 2012, 12:24:25 AM »
Per the 1965 Mustang Body Assembly manual (AM0006), pg 62 (N5-8907), the part number for the bushing is C5ZB-63448A04-A. That number does not appear in the Ford Car Parts book in either the illustration section or the full part number listing section.
I entered the wrong p/n - "Damn these eyes" - Igor in Young Frankenstein
« Last Edit: February 10, 2012, 12:28:05 AM by jwc66k »
« Reply #14 on: February 10, 2012, 02:03:35 AM »
Try http://www.wclco.com/pdf/plastics/074.pdf
It was one of 500 or so links from the Yahoo advanced search function exact phrase using "nylon flanged bushings".
I don't have all the dimensions so somebody needs to do some measuring.
