Author Topic: drive shaft stipes  (Read 3714 times)
Offline Stangly
  • Gold Level Subscriber
drive shaft stipes
« on: February 05, 2012, 01:15:11 PM »
I have my original build sheet which shows the stripes to be light blue dark green yellow (LB DG YL).  The drive shaft is not original to the car, but since I have the build sheet I would like to put them on the used shaft I found.  The question is the location of the stripes.  I have looked at examples of dearborn cars from the same years and they all seem to have a single stripe (color varies) at the rear and a series of 3 or 4 in the middle.  I'm not sure what order and where these three colors I found on the build sheet might have been placed.  I did see in one post that the order of the colors is from front to back.
David,
68 Coupe J-Code
2001 V6 Laser Red
2015 GT Deep Impact Blue
Re: drive shaft stipes
« Reply #1 on: February 05, 2012, 11:15:17 PM »
Normally the stripes start about a third to a quarter of the way back and normally follow the build sheet (as they are listed) front to back
Offline Stangly
« Reply #2 on: February 06, 2012, 08:59:10 AM »
Jeff,
Is there typically a group of them a third of the way back and then one solo stripe at the rear end.  The replacement shaft I found has a group of three about the middle and then one single stripe at the rear.  These colors don't match my build sheet but I figure the location gives me a good starting point.  Not sure what plant this replacement shaft came out of?
Thank you,
David,
68 Coupe J-Code
2001 V6 Laser Red
« Reply #3 on: February 06, 2012, 09:33:10 AM »
I don't know if it will help but here is my late SJ 68 289 2V auto shaft. Marty
« Reply #4 on: February 06, 2012, 11:01:26 PM »
Jeff,
Forgive me  (and thanks Marty) was recalling early driveline markings rather than 68 - up ones. Yes those were often marked with the id marks sort of in the middle and sometimes with a fourth mark towards the rear.
Again sorry for the confusion but it does demonstrate the value of an open forum where things can be caught and corrected quickly.
Marty - did you find orange on your driveline ends when you cleaned them? Thought those were smaller ends than the CJ - Hmm guess I need to look at the books
Offline BBs70fastback
« Reply #5 on: February 07, 2012, 03:19:24 AM »
Here are pictures of my driveshaft off my 1970 Dearborn sportsroof, that just came out of an evaporust bath, showing various markings.  Both ends of the driveshaft appeared to be red oxide-ish, and the transmission yoke end may have been completely yellow.  My stripes in the middle were light blue, white? and yellow, with maybe a double brown stripe toward one end?  (I thought it might be rust residue until I saw other pictures with stripes in that area).
Hope this is of some help.
Barry
First Restoration - going for original driver
1970 Sportsroof 302 2V, Dearborn, built June 17, 1970, power steering, Auto, A/C, Y code Chestnut Metallic, standard black interior
« Reply #6 on: February 07, 2012, 09:36:14 PM »
Though it might not help allot in this discussion (different year application) what transmisson did your 1970 Sportsroof 302 2V, Dearborn, built June 17, 1970 come with ?
« Reply #7 on: February 08, 2012, 01:01:11 AM »
My 70 has an automatic transmission.  (I will add that to my signature line).
Offline app01
« Reply #8 on: May 16, 2012, 12:58:50 PM »
here is a pic of my 70 Mach 1, 351C, FMX, Metuchan built, with the exact locations of the original stripes..
Hope this helps.
Currently own:
1962 Corvette 340hp
Previously Owned:
1970 Mach 1 (my 2nd car)
1989 GT
MCA #62598
www.PalmieriConcepts.com
