Author Topic: Wiper Arms  (Read 2380 times)
Offline sparky65
Wiper Arms
« on: February 03, 2012, 04:11:17 PM »
Is there any way to refinish wiper arms?  It looks like part is stainless but the other part that goes on the shaft appears to be some pot metal.  I was going to try to sand and polish them until I realized they are supposed to be satin finish.  Not sure how to recreate that.   :-\
Steve
2009 Black GT Coupe
Re: Wiper Arms
« Reply #1 on: February 03, 2012, 04:29:07 PM »
Might be able to play some tricks with buffing and then hitting real light in the blast cabinet with glass bead.  Probably a combination that will work.  Otherwise, paint is another option.
Re: Wiper Arms
« Reply #2 on: February 03, 2012, 11:01:01 PM »
Or replace them with a better set
Offline 69RavenConv
  • Owner since '74
Re: Wiper Arms
« Reply #3 on: February 04, 2012, 12:12:04 AM »
Motorcraft argent paint does a pretty good job.
Phil
'69 Convertible - Dearborn June 4, 1969 - Raven Black & Red - 302-2V
Re: Wiper Arms
« Reply #4 on: February 04, 2012, 12:50:14 AM »
Let me guess, something you just go to the scrapyard and pickup whenever you need?  ;-)
Offline sparky65
Re: Wiper Arms
« Reply #5 on: February 04, 2012, 09:52:38 AM »
Might try that.  Apparently the pot metal was chromed.
Steve
2009 Black GT Coupe
Offline TLea
Re: Wiper Arms
« Reply #6 on: February 04, 2012, 10:16:04 AM »
Don't even go there, it will just leaqve you wanting  ;)
Offline e093116
Re: Wiper Arms
« Reply #7 on: February 04, 2012, 02:47:27 PM »
I restored a set of satin finish wiper arms for a buddy's 66 with the following process that turned out pretty nice:
1.  Cut - use 3M Scotch Brite EXL deburring wheel to remove haze, tarnish, and restore surface from areas on wipers arms that are stainless.  Don't hit the pot metal part with this.  I think I used an 8S FIN wheel, but may have used one grade coarser.
2.  Buff - green and/or black rouge on hard cotton buff wheel.  Just enough to "even out" the stainless surfaces cut in the previous step.
3.  Polish - Simichrome on soft cotton buff wheel.  Just enough to give the "color" you are looking for.  Include the pot metal area in this step.
Of course, I didn't have an nice original set of wiper arms to compare the results from this process against, so YMMV depending on your criteria.  But the Scotch Brite wheels are made for finishing stainless steel in particular and I thought this was a better alternative than painting.  If you read the product literature on the 3M unitized (and also convolute) wheels, you can see what is recommended for jobs like deburring turbine blades to putting satin finish on stainless steel silverware...
65 San Jose Fastback, May 15 build date
