Author Topic: 65-66 OEM 9-inch U-joint bolts  (Read 1395 times)
Offline s2ms
    • 6S1757 Info
« on: January 29, 2012, 03:54:12 PM »
The bolts pictured are Ford service parts for the 9-inch rear end. Did OEM bolts have the raised pad at the rear or were they smooth?
Dave
Re: 65-66 OEM 9-inch U-joint bolts
« Reply #1 on: January 29, 2012, 04:54:21 PM »
Originals I have seen have some type of circular pattern at the top.  Usually does not stick up though.
Offline s2ms
    • 6S1757 Info
« Reply #2 on: January 30, 2012, 02:57:57 PM »
Thanks Charles. Anyone have a pic of an OE bolt?
« Reply #3 on: January 30, 2012, 03:36:05 PM »
The bottom one in your pic looks pretty close.
Offline s2ms
    • 6S1757 Info
« Reply #4 on: January 30, 2012, 03:56:43 PM »
Thanks, both bolts are identical, I think the circular pad is just a little more pronounced in the top one because of the lighting...
