Author Topic: 65-66 Steering Column Bracket  (Read 4093 times)
Offline kutzoh
  • Gold Level Subscriber
« on: January 29, 2012, 10:18:31 AM »
Is there supposed to be a rubber pad that goes between the steering column and the bracket that mounts under the dash? Not talking about the firewall but the bracket that snugs the steering column to the bottom of the dash.
Greg
Re: 65-66 Steering Column Bracket
« Reply #1 on: January 29, 2012, 10:55:17 AM »
yes. i have made a few out of old bicycle inner tubes.
« Reply #2 on: January 29, 2012, 12:44:25 PM »
There is also a paper spacer involved, going between the upper bracket and the dash. Give me a couple of hours and I'll scan my drawings and post them. It's too early in the AM to think, scratch and eat.
Offline kutzoh
« Reply #3 on: January 29, 2012, 01:46:31 PM »
Thanks guys for the replies.
Greg
« Reply #4 on: January 29, 2012, 03:48:22 PM »
Pictures -
1. The paper insulator. For color see the 3rd and 4th picture.
2. The rubber insulator. It was held in place with contact cement. I used 3M8001 yellow weatherstrip adhesive.
3. Original material - LH top, 67 rubber, 67 paper and 67 paper intact; RH top, my repro rubber, my repro paper, orig San Jose Oct 65 build paper.
4. What's going on my 66 "K" car, San Jose Oct build. Note "pin" type locking nut.
All dimensions are based on 2 ea, 1965 (Sept, May), 4 ea 1966 (Oct, Dec, Jan, Feb) 1 ea 1967 (May), all San Jose cars.
« Reply #5 on: January 31, 2012, 02:11:32 AM »
Pictures -
You mean they all didn't have the finger/pin?  ;) Seen plenty with it - guess I never paid much mind to the others
« Reply #6 on: January 31, 2012, 09:09:53 AM »
Don't think it was mentioned, but the top bracket with the paper piece is always semi-gloss black, not interior color.  The lower collar is obviously interior color.
Offline rodster
« Reply #7 on: February 04, 2012, 05:52:55 PM »
Always like to share a picture if possible.
65 Dearborn  April 19 build date
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline cobraboy
« Reply #8 on: February 05, 2012, 05:38:27 AM »
Thanks for all the info, this is perfect timing for me as I have the column out of the car at the moment.
13th April 1965 Dearborn K GT on the other side of the pond.
« Reply #9 on: February 05, 2012, 01:52:59 PM »
There are two types of center lock "staked" lock nuts, ones with a round indent, the "pin", and others with a slot, both identified with the same part number, 55802-S, 5/16-18 hex nut, 1/2 hx, 17/64 in thk. Applications are: 64-67 steering column mount, -S8 ?, pin and slot; 67 bumper to end bracket, -S2 ?, slot; 64-66 (-67, 68 ?) vent window spring retaining, -S8 or -S7, pin. I believe it's because of mutiple suppliers.
« Reply #10 on: February 19, 2012, 06:01:40 PM »
Charles, you are correct again. I removed the clamp from my relatively untouched 66 "K" car (Oct 65 San Jose build) and it was black, not semi-gloss black but a very glossy black. The paper insulator was the same color as my pictures show. It occurred to me why I assumed the bracket was interior color and the answer was simple, the last four cars I worked on in that area had a black interior.
Assume nothin' -
Offline jwoo
« Reply #11 on: November 07, 2024, 12:01:43 PM »
Thanks for the posts on this thread. I'm restoring mine. I did need to replace the Paper. But, I noticed the original rubber on my 66 San Jose car is 1-1/2" wide (A).
