Author Topic: Cleaning plastic lenses  (Read 3454 times)
Offline Oz390
« on: January 20, 2012, 10:43:05 PM »
Probably known, but new to me.
Had some '68 front side marker lights I am restoring.  The old lenses were white-ish and grubby.  Soaked them in a strong caustic soda/lye solution overnight and they came out looking almost new.... no buffing to wear down letters, and a very good result, to me....
Going to try it on a pair of Cal Special taillamp lenses that are pretty grubby, with the "waffle" pattern on the backside almost impossible to clean with mechanical methods...
8R03S : 76A I 2A 15M 72 5 U
Offline C5ZZKGT
  • Gold Level Subscriber
Re: Cleaning plastic lenses
« Reply #1 on: January 21, 2012, 08:31:23 AM »
Interesting.....can you tell us more about your procedure and exactly what you used? where can caustic soda and lye be purchased today?
« Reply #2 on: January 21, 2012, 06:21:08 PM »
I did a web search and came up with some HD drain cleaner from Home Depot. Have not set up a bucket yet to experiment with it as of yet Will see if I can find the name of the stuff and post the make up of the concentration
Offline 69RavenConv
  • Owner since '74
« Reply #3 on: January 21, 2012, 10:37:37 PM »
Yes, please elaborate. I'm sure there are many of us who would prefer to rejuvenate our old lenses rather than replace with reproductions.
Phil
'69 Convertible - Dearborn June 4, 1969 - Raven Black & Red - 302-2V
Offline hkopp
« Reply #4 on: November 18, 2012, 10:05:53 PM »
has anyone found more info on the product available for this cleaning method?  i am restoring a set this week and came across this tonight in a search, would LOVE to use something to clean my lenses as described.  Also...what do most do to obtain the correct color of 69 front signal enclosures without sending out for dipping?
1956 Ford F100
1959 Galaxie
1960 Chevy k10 sb
1965 Mustang 347, 5 spd, 1st car!
1967 Camaro SS350 all #'s
1967 S code
1969 Mach 1 428SCJ-R #'s
1969 Mach 1 428CJ-Q Auto
1969 Mustang Grande, 650hp, 2nd car!
1970 Mustang
1970 Mach 1 351C
1975 Ford F250, 44s, 21" lift, 3rd car!
2002 Avalanche
2011 Vette
« Reply #5 on: November 19, 2012, 10:42:21 PM »
Will address the second half since I've not found a chemical treatment that helps the irregular surface plastics
As for faking zinc dischromate on a large surface I have yet to see anything that does a good job. Have used the spray can Eastwood produces for tocuhing up spots or on small screw heads but I have not found a shortcut acceptable to me and other judges
Offline 69RavenConv
  • Owner since '74
« Reply #6 on: March 31, 2013, 12:41:56 PM »
Bumping an old thread because I'm wondering if anyone has learned any more about this method. I have some discolored OEM lenses and was thinking of trying some drain cleaner on them as they are unusable now anyway.
Phil
Offline Stangly
« Reply #7 on: March 31, 2013, 02:23:11 PM »
I did some snooping on the internet and a caustic lye is made up of sodium hydroxide.  This is the common ingredient in most drain cleaner.  I bought a basic granular drain opener and Lowes, the product is 100% sodium hydroxide as is nasty stuff.  I'm not a chemist so please read the warning labels on the product you purchase.  I soaked some parking light lenses in the solution overnight and they came out great.
68 Coupe J-Code
2001 V6 Laser Red
2015 GT Deep Impact Blue
