Greetings from another new guy. Recently found this excellent forum and have spent a few days reading posts. Bought this 66 Sprint last July and other than putting a carb kit in it so it would run without stalling, haven’t done much other than research and just driving it. From what I’ve been able to learn, if I’m reading the codes correctly, (in my signature) it seems fairly early for a Sprint?
Thanks for your help, yet at risk of putting too many questions in one overly long post;
It’s missing the wire wheels. I may have found a set of wires wheels locally, if they are correct. Is there a link that shows the correct wheel/spinner/emblem? Any advice what a used set should cost – with or without any curb rash?
I’ve seen posts referring to a buck tag and I don’t see one at the left inner fender where I think it’s supposed to be? I understand from other posts that a San Jose car may not have a build sheet - and I haven’t found one – perhaps the same with the buck tag?
Although this car spent much of it’s life in Arizona and appears to have all of its original panels, interior and drivetrain,, I don’t believe it qualifies as a survivor as it was repainted in the ’80s and the thermactor system has been pulled - except for the remaining capped injection manifold, unused pulley on the crank and hose nipple on the back of the air cleaner housing, etc.. Have I read correctly that Ford initiated the removal of some thermactor systems as although they reduced one pollutant, that substantially increased another, or is that a myth?
At this point I would like to get the car into a condition as it may have appeared as a well maintained common mans daily driver with a just couple years wear in the late ‘60’s. Any resources that I could be pointed to with that intent would be greatly appreciated.
