Author Topic: roof rail weatherstrip channel sealer  (Read 1547 times)
Offline rayms69
« on: January 15, 2012, 06:33:51 AM »
 Has anyone the sealer between the stainless and body, is the 3M tape the way to go. Strip caulk? Not worried about the cost, just want to do it right.
10-26-1969 Dearborn 428 SCJ auto
Re: roof rail weatherstrip channel sealer
« Reply #1 on: January 15, 2012, 08:08:35 PM »
Just used 3M double sided black foam tape
« Reply #2 on: January 15, 2012, 10:30:07 PM »
+1. Bob
Offline cobrajetchris
« Reply #3 on: January 16, 2012, 11:24:40 AM »
I used the 3M double sided tape and it worked great. I would also recommend buying the adhesion promotor that 3M sells in little packets, it should be on the same shelf with the tape.
CHRIS KNOBBE
Offline rayms69
« Reply #4 on: January 16, 2012, 04:48:38 PM »
Ok sounds good.
