Author Topic: 67 to 70 black interior paint  (Read 9764 times)
Offline mustangfan
« on: January 11, 2012, 07:24:08 AM »
My question is related to the Dark charcoal metallic paint used in the  interior dash and door areas in the       67 cars,is it the same all the way up to the 1970 cars?
Re: 67 to 70 black interior paint
« Reply #1 on: January 12, 2012, 02:30:35 AM »
Believe so - don't see a change in the paint code
« Reply #2 on: January 12, 2012, 04:07:34 AM »
+1
Offline mustangfan
« Reply #3 on: January 12, 2012, 07:18:19 AM »
Thanks,I had some left over from my 70 Boss and had been told it was different for the 67.just wanted to be sure.
Offline 1Hotboss
« Reply #4 on: August 06, 2012, 07:10:25 PM »
could someone tell me what paint I would you for the interior panels, semi gloss, flat etc..and which type of brand is reccomended ..Thanks
« Reply #5 on: August 06, 2012, 07:36:57 PM »
Are you looking for rattle/spray cans or from a paint gun?
If from a paint gun - enamel, water based, lacquer?
Offline 1Hotboss
« Reply #6 on: August 06, 2012, 09:29:20 PM »
Looking for a spray can..thanks
and thats the question...looking to repaint my dash for my 68 fastback...would sem interior paint be my best bet or something else..thanks
« Reply #7 on: August 06, 2012, 11:55:01 PM »
yes 67-70 the same. 65/66 is semi black. Sems interior paint is semigloss black . Your dash is Dark Grey metallic. NPD sells a rattle can .I don't like rattle can for this situation but use a base coat of semigloss black krylon and overcoat it with the rattle can Dark Grey metallic because it goes on thin and does not cover when hence the semi black base coat.
Offline 1Hotboss
« Reply #8 on: August 08, 2012, 12:52:04 PM »
Thanks Bob, I just have a tiny area above the glove box to touch up, I do have SEM interior trim spray can..would this work...Thanks
« Last Edit: August 08, 2012, 12:58:33 PM by 1Hotboss »
Offline craig429
« Reply #9 on: August 08, 2012, 06:09:33 PM »
If rattle cans are not the best for this application, what spray gun paint do you recommend?
1969 Mustang Mach1 390
« Reply #10 on: August 08, 2012, 10:57:57 PM »
You apparently did not understand the content of my last post. The sem product is black. Your dash is the dark grey metallic so it will not work.
« Reply #11 on: August 08, 2012, 10:59:46 PM »
I use PPG products. The ppg product is also thin and you need to apply a base coat as discribed before topcoating with the PPG paint.
« Reply #12 on: August 08, 2012, 11:00:50 PM »
I use rattle can stuff all the time though some prefer spray gun stuff. Challenge we have here locally is that we're changing over to all water based s**t  so allot of stuff can't be painted legally - locally.
For a gun I would get some PPG Dark Charcoal Metallic. This may be available for you locally or can be ordered out of San Diego CA from the Auto Color Library (one of a number of business names they use.
Offline craig429
« Reply #13 on: August 08, 2012, 11:12:58 PM »
Is the PPG number 32586 for Dark Charcoal Metallic?
« Reply #14 on: August 08, 2012, 11:53:07 PM »
Originally the Ditzler/PPG number was #9295 not sure what the current equivalent (if there is one) would be
