Author Topic: 65 Heater Motor  (Read 8563 times)
Re: 65 Heater Motor
« Reply #15 on: January 11, 2012, 12:18:27 AM »
Never seen friction tape used. One of the current beliefs is that the tape held the short wires to the motor as it was inserted through the hole in the firewall
I found friction tape on the blower motor on a San Jose build May 67 Fastback. The car was found in a field in West Oakland and restored to daily driver standards. I used 2 inch wide cut to 1 inch 50 plus year old friction tape I got from my father's junk that was used by the US Navy at NAS Moffett. It passed Jeff's inspection in the last MCA event at Concord.
Re: 65 Heater Motor
« Reply #16 on: January 11, 2012, 10:41:20 PM »
Doesn't make sense to me to hold the wires in place while inserting the motor housing through the firewall, as the wires exit the end of the motor housing.  With the wires taped to the sides, either the plugs themselves were taped, in which case the wires could catch on the housing, or if only the wires were taped, the bullet plugs would catch on the housing.  IIRC, it's a fairly tight fit through the firewall hole.
Re: 65 Heater Motor
« Reply #17 on: January 11, 2012, 11:23:32 PM »
I also don't believe the tape was to hold the wires.  If that was the case, we'd have seen at least some early service replacements with the wires held to the tape and some ripped tape on original cars.  I believe the tape is there to help keep moisture out of the motor.
Re: 65 Heater Motor
« Reply #18 on: January 11, 2012, 11:48:10 PM »
I never considered the tape to be a wire installation aid. I assumed it was as Charles stated, a moisture barrier, a flimisy moisture barrier. Keep this in mind when you look at a 60's vintage car - the mentality of the auto manufacturers then was a two year turn, everybody buying a new car every two years, ergo, cars were designed to last a short period of time, and the parts and materials used reflected that. Reliability was not a selling point.
Offline Texas Swede
Re: 65 Heater Motor
« Reply #19 on: January 16, 2012, 02:26:07 PM »
I got the tape from Jack and have a question. How many laps around the motor should i mount the tape?
Somebody suggested 2-3 laps but is that correct, or should it be one lap?
Texas Swede
Re: 65 Heater Motor
« Reply #20 on: January 16, 2012, 03:59:17 PM »
Texas Swede
Normally see about 1 1/4 to 1 1/2 laps around.
Offline Texas Swede
Re: 65 Heater Motor
« Reply #21 on: January 17, 2012, 12:11:50 AM »
Thanks Charles,
Texas Swede
Offline Texas Swede
Re: 65 Heater Motor
« Reply #22 on: February 04, 2012, 04:53:44 PM »
Put the tape from DeadNutsOn on my heater motor. Was very tricky when the motor is in the car
but finally I was able to get it there and it looks real good. Thanks for all the help I got.
You guys are the best.
Texas Swede
Offline 66RavenGTCoupeAgain
Re: 65 Heater Motor
« Reply #23 on: January 17, 2018, 06:02:17 PM »
Great info here. So am I right in saying that the tape is 1" wide? Was it painted or left natural?
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
Re: 65 Heater Motor
« Reply #24 on: January 17, 2018, 06:14:37 PM »
On something like a concours car, I have spray painted 1" wide masking tape and wrapped it around the motor.  For the T-bred stuff, I would use an NOS motor like in the picture above that has the original tape.
Semi-gloss or satin black spray paint, nothing fancy.  Few light coats just to cover.  The stuff Jack sells looks nice though.
Mid: I suppose it was just a little something extra to keep moisture from getting inside the motor.  The motor housing separates at that joint.
Re: 65 Heater Motor
« Reply #25 on: January 17, 2018, 06:22:41 PM »
Thanks! ;D
Re: 65 Heater Motor
« Reply #26 on: January 18, 2018, 12:57:07 PM »
I've found black masking tape, 1" wide.  Easier than having to paint regular masking tape.
Some of the NOS heater fans have a grayish look to the tape, but this varies.
Re: 65 Heater Motor
« Reply #27 on: January 18, 2018, 04:20:47 PM »
May just be age or long term reaction between different underlying products (metal verses the tape)
Have notice it too on ones stored away in boxes
