Author Topic: Vacuum Fitting ID?  (Read 876 times)
Offline sah62
Vacuum Fitting ID?
« on: January 02, 2012, 05:42:29 PM »
Can anyone identify the original application (if any) for the brass vacuum fitting in the attached picture? I found it in a box of parts with no label, so I have no idea where it came from beyond knowing that if I have it it might have had something to do with a 1970 Mustang. It's got three small Weatherhead logos stamped on top.
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Re: Vacuum Fitting ID?
« Reply #1 on: January 02, 2012, 07:35:03 PM »
Holley carb rh side metering block yellow vac hose to top of tree. I have seen some late 70 71 holley carbs with the straight out nipple there also.
Offline sah62
« Reply #2 on: January 02, 2012, 07:48:36 PM »
Thanks!
Scott Hollenbeck
