Author Topic: 67 door hinge bolts  (Read 2702 times)
67 door hinge bolts
« on: December 26, 2011, 10:12:36 AM »
What are the correct bolts used for 67 door hinges, both to the door and the A pillar?  I've got three types right now; (1) "23" with serrated cup washer, (2) "double quote" with tooth washer, and (3) SEMS with serrated cup washer.  Dec 1966 San Jose build.  Thanks John
Re: 67 door hinge bolts
« Reply #1 on: December 26, 2011, 07:35:14 PM »
Took a look at the pictures I have and from that period I found the following''
« Reply #2 on: December 26, 2011, 08:52:23 PM »
Thanks Jeff.  Like the pics, my upper hinges also have the body caulk arount the top hinge (only). John
« Reply #3 on: December 26, 2011, 10:25:41 PM »
Top most picture shows the "23" on the A pillar
Yes during that period they seem to only apply the sealer to the top hinge on two side - right out of the chalking gun
Re: 67 door hinge - sealer
« Reply #4 on: December 28, 2011, 07:06:31 PM »
I had sealer all away around the top hinge, none on the bottom.  Should I recreate the same way?
« Reply #5 on: December 28, 2011, 08:24:00 PM »
Most likely was there, possibly not as much as the top hinge though.
« Reply #6 on: December 29, 2011, 03:45:24 PM »
Yes - its not unusual for a worker to do a little extra or slightly different from another, as long as the areas that were the suppose to be covered got covered
Offline rodster
« Reply #7 on: January 17, 2012, 12:24:54 AM »
67 Dearborn for reference.
02/07/67 build date
« Last Edit: January 29, 2012, 12:07:38 AM by rodster »
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
« Reply #8 on: January 17, 2012, 08:57:52 PM »
For those that will view this thread later - when was the Dearborn example assembled?  ;)
Offline rodster
« Reply #9 on: January 29, 2012, 12:08:42 AM »
Ooops  forgot that. I edited the post an added the build date.  02/07/67.  Thanks for keeping on top of things!  ;D
1984 SVO - 2A
