Author Topic: 67 lower door hinge fix  (Read 1114 times)
Online 67gta289
« on: December 25, 2011, 03:42:07 PM »
One of my lower door hinges has a cracked rotating collar, see the picture.  Is this repairable, or should I look for a replacement? Thanks John
Re: 67 lower door hinge fix
« Reply #1 on: December 25, 2011, 08:55:22 PM »
John those bushings are normal wear items. They are included in the complete hinge rebuild kits. It takes a little more time to replace all the parts but your door will work a lot better if you do. Marty
Online 67gta289
« Reply #2 on: December 25, 2011, 09:46:57 PM »
I looked quickly and only saw the pins in the kits - will look at the full kit. Thanks Marty. John
Offline sparky65
« Reply #3 on: December 26, 2011, 10:06:02 PM »
You will probably want to replace the pin anyway as they tend to wear.  Cant remember where I bought my kit but I had to cut the pins to the right size.  They were way too long for some reason, probably a one size fits all thing.
Steve
2009 Black GT Coupe
