Author Topic: Big Block 4-Speed Z-Bar Springs  (Read 2623 times)
Offline Stangman68
« on: December 17, 2011, 12:39:06 PM »
I have a 69 428 SCJ 4-Spd car.  The z-bar has both an upper and lower spring.  The lower spring is easy to figure out where it attaches...the upper no so much.  On 67/68 modles there is a bracket that attaches to the emergency brake firewall side...this bracket has a hole in it to attach the spring.....69/70 models do not have this bracket and i can't for the life of me figure out where to attach this upper spring.  any assistance woluld be appreciated.  my email is:  stangman68@mediacombb.net
Re: Big Block 4-Speed Z-Bar Springs
« Reply #1 on: December 17, 2011, 02:24:48 PM »
the long end hook goes in cutout  at top bar by curve and short end on lite blue spring hooks on a small raised metal tab on metal plate by steering column hole below booster and very hard to hook on firewall after booster and engine installed.
Offline rockhouse66
« Reply #2 on: December 17, 2011, 03:08:13 PM »
Adding to Ed's response, here is a picture that will at least show you where to grope for the firewall tab.  You can't actually see it here, but you can identify the location at the end of the blue spring.  Obviously, not a PB car.  And yes, I know the Z-bar should not be zinc  ::)
'66 GT FB
« Reply #3 on: December 17, 2011, 05:01:24 PM »
ZINC z-bar in late 70 and they changed the lower pin size bigger when they sold them as dozzs
Offline svo2scj
« Reply #4 on: December 18, 2011, 11:48:18 AM »
Be Prepared for this !
After an hour of trying I stepped back, opened a beer.  installed the spring on a "flexible grabber" and FISHED it into the slot on the firewall. (It took about two beers)
Mark
« Reply #5 on: December 18, 2011, 12:34:21 PM »
Ya did good, lad. I figure at the end of the day, if I ain't cut and bleeding, the day was not good. And the beer helps the pain.
Offline Stangman68
« Reply #6 on: December 19, 2011, 08:50:50 PM »
 >:(  Great, i wish i knew that before i put the engine in....to be honest, I really don't recall seeing any eyelet in that location...did all 69/70 cars have the eyelet, regardless of automatic/standard trans???  or is it an eyelet that bolts on???
« Reply #7 on: December 19, 2011, 10:37:39 PM »
Just a small raised metal hump stamped outward on metal reinforcement plate spot welded to firewall for booster and steering column mount.
« Reply #8 on: December 19, 2011, 10:53:40 PM »
In the pictures I have the tab is there on original automatic as well as manual cars in 69
