Author Topic: Vent Window Gasket?  (Read 2311 times)
Offline MWM
Vent Window Gasket?
« on: November 30, 2011, 11:07:39 PM »
I am replacing the glass on my vent windows.  I have removed the glass from the stainless steel frame (backwards 'L' shape) and the gasket that held the glass in place is brittle and missing in places.  I am told there is not a replacement, what is a good work around?
Thank you!
Re: Vent Window Gasket?
« Reply #1 on: December 01, 2011, 12:02:43 AM »
This is simply glass tape and can be bought online in different thicknesses.
Offline MWM
Thank-You Charles!
« Reply #2 on: December 01, 2011, 10:28:18 PM »
I am on my way to check it out!
Thanks!
« Reply #3 on: April 28, 2015, 09:58:37 PM »
Any tips and tricks on removing the glass from the frame?  Thanks
« Reply #4 on: April 28, 2015, 11:22:35 PM »
Yes, think - "remove the frame from the glass". I use a narrow screwdriver and gently pry the frame from the glass. I'm still at 100 percent intact and reusable.
Offline suskeenwiske
  • 214-347-3628
« Reply #5 on: April 29, 2015, 11:48:04 AM »
You may also look into a couple of 3-M Products; Windo-Weld and Glazing Urethane.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
