Author Topic: build sheet wheel code  (Read 3014 times)
Offline x66fastbackx
« on: December 04, 2009, 11:19:33 PM »
I have my build sheet for my 66 an was wondering is there a spot on the sheet that describes what rims came with the car (styled or black steel)  here is a link of my build sheet though I do have a better copy.
http://www.cardomain.com/ride/2125621
thanks john
Re: build sheet wheel code
« Reply #1 on: December 05, 2009, 12:55:07 AM »
The flash on the picture obscures the Wheel section, which is 2 to the right of the Battery section on the bottom row.  If you post the code, we can tell you what wheels/wheel covers were ordered for the car.
« Reply #2 on: December 05, 2009, 05:40:34 PM »
There is no code in this box marked WHL CVR/ FEND SHLD .It is blank. I guess this means black steel wheels with standard hub caps. Wow but its a GT.
In the tire section it says tire C type 1
« Reply #3 on: December 05, 2009, 06:17:13 PM »
Yep, that's what it means.  Sorry!
« Reply #4 on: December 05, 2009, 09:59:14 PM »
thanks at least I can have 14 in white walls yea.
thanks again
Offline JKWilson
« Reply #5 on: December 05, 2009, 10:45:41 PM »
To elaborate a little on your tire codes, the "C" stands for 6.95x14, and the "1" stands for rayon white sidewall tires.
« Reply #6 on: December 06, 2009, 11:48:47 AM »
I should send you all a copy of my build sheet as there are a few other unknown codes on it.
« Reply #7 on: December 06, 2009, 11:54:17 AM »
This might help:  http://www.early-mustang.com/charles/66_order/66order.htm
