Author Topic: brake drums  (Read 2357 times)
Offline hoppin67
brake drums
« on: November 11, 2011, 05:14:48 PM »
im restoreing a 68 shelby gt500. there is white paint on face of rear drums, was told this was factory done? im restoring this to concours so really could use input. also wondering if 69 parts were concours for this year? thanks
Re: brake drums
« Reply #1 on: November 11, 2011, 07:31:27 PM »
You were misinformed on the the white paint being factory applied on the face of the brake drums . The white paint was most likely past owner applied. They would be cast iron gray typically or possibly given a brushed on black out treatment . All 68's came with hubcaps from the factory . The hubcap cars did not typically receive a black out treatment like the deluxe wheel equipped cars . FYI only about 5 cars are documented from the factory (very early production) to have received the 67 style tenspoke deluxe wheels and they were all sent overseas. I am not quite sure what you mean about if 69 parts are concours for 68. Some 68 parts were also used on 69 cars . If that is what you mean you would have to ask that question on the specific item or items in question to get a appropriate answer. I hope this helps . Bob
« Last Edit: November 11, 2011, 07:34:05 PM by Bob Gaines »
Offline TLea
Re: brake drums
« Reply #2 on: November 14, 2011, 03:28:55 PM »
You will sometimes see white (also light blue) on the ends of the axles but I've never seen white paint on brake drums of a 68 shelby
Re: brake drums
« Reply #3 on: November 14, 2011, 07:01:34 PM »
Have seen white, red, orange and blue on the rear brake drums of many Mustangs (looks cool when you can see it through the wheel openings) but IMHO not original ;)
Offline 68 S Code
Re: brake drums
« Reply #4 on: November 17, 2011, 05:09:01 PM »
+1 on Tims observation of white on the end of axles.
« Last Edit: November 17, 2011, 05:11:37 PM by 68 S Code »
Re: brake drums
« Reply #5 on: November 17, 2011, 05:56:33 PM »
Have seen light blue on the end of a 68 small block (8") San Jose car (should not be plant specific IMHO) on the drivers side that appeard to be original
