Author Topic: July '65 Dearborn Alternator spacer  (Read 1598 times)
Offline C5ZZKGT
  • Gold Level Subscriber
« on: November 11, 2011, 11:47:57 AM »
What finish should this be please?
Offline ChrisV289
Re: July '65 Dearborn Alternator spacer
« Reply #1 on: November 11, 2011, 01:57:16 PM »
What motor is in the car?
2009 V6 Mustang Coupe
Offline C5ZZKGT
« Reply #2 on: November 12, 2011, 07:23:41 AM »
Whoops.....K code Hipo 289.
Offline ChrisV289
« Reply #3 on: November 12, 2011, 09:25:33 AM »
I believe it should be a dark steel color...the gold one wasn't used till 66....
« Reply #4 on: November 12, 2011, 12:03:21 PM »
Typically the dark color is the result of a plating over the steel spacer . It can be replicated by black oxide or gun blueing proceeder. The part  was transitioned to the aluminum spacer that was color anodized sometime near or at the 66 model change over . After the transition gold was typically the small block color as mentioned . Bob
Offline C5ZZKGT
« Reply #5 on: November 12, 2011, 03:49:27 PM »
Thanks Guys!! I appreciate the help!
Offline 66RavenGTCoupeAgain
« Reply #6 on: November 27, 2018, 06:27:44 AM »
Hi Guys,
So what colour should it be on a oct 64 built C Code?
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
« Reply #7 on: November 27, 2018, 09:33:22 AM »
please reread reply #3. the answer is there.
