Author Topic: Wiper nozzels finish  (Read 2839 times)
Offline 68 S Code
« on: November 08, 2011, 04:31:42 PM »
I started a thread in the suspension section on restoring some rear leaf springs and wandered off thread talking about Insta-blak finish and windshield fluid nozzels. As mentioned I spoke with Bob P about the nozzle finish and he mentioned that they should be a dark brown. Below is a pic of some nozzles which i cleaned in evaporust and it is clea that they were zinc dichromate with a dark finish applied over the top. i have heard it was black oxide in other threads. That is why i purchased the Insta-blak poduct as i heard it gives you that black oxide finish in a DIY treatment. Question is shoulkd it be black or dark brown. I'm only seeing blackish grey. The one on the far right with the hose attached hasnt been cleaned sitting on the shelf for 3 decades.
Offline TLea
Re: Wiper nozzels finish
« Reply #1 on: November 08, 2011, 05:05:47 PM »
The blackish gray is correct. Its always been a bit of a mystery what the original finish was
« Reply #2 on: November 08, 2011, 07:14:00 PM »
Does the dark finish apply to the complete assembly, bracket and tube? John
Offline 68 S Code
« Reply #3 on: November 08, 2011, 07:56:13 PM »
John from the pics you can see that the stem and the mounting bracket were all dark.
« Reply #4 on: November 08, 2011, 10:20:42 PM »
You can occasionally find NOS 68 squirters with the blackish gray finish for sale on ebay and what not. I have heard by others but not seen personally that some of the 68 side marker backing plates were plated with a similar looking plating too. I trust the observations and think it is a production variation by a alternate vendor on the backing plates. All of the backing plates I have come across (where I could still tell the original finish) were zinc dichromate.Bob
Offline 68 S Code
« Reply #5 on: November 09, 2011, 09:50:15 AM »
I've only seen the marker light and turn signal brackets in ZD. I will look more closely in the future for signs of the black oxide. If anyone has used the insta blak product please post any application tricks or things to watch out for. My nozzelsmaremcurrently ZD so Im getting ready to give it a try. I've seen it just sprayed on a cleaned piece. Do you just spray and let it dry? Do you need to add a product like Boshield?
Offline TLea
« Reply #6 on: November 09, 2011, 01:44:13 PM »
Not trying to get off subject here but I've seen several of those "dark" marker light retainers. It appears different than the washer nozzle finish and clearly has an irradescense (sp?) to it like the finish is over the ZD. I've often thought they might be done in a ZD solution that was contaminated
« Reply #7 on: November 09, 2011, 03:43:13 PM »
;D ;D ;D I never thought of it that way. Tim you are always thinking outside the box. Bob
Offline Scott Fuller
    • Scott Fuller Reproductions
« Reply #8 on: November 09, 2011, 05:00:52 PM »
Who let Tim out of his box?
Scott
68 "135" Mustang, 68.5 Blck Mustang CJ Cnvrt, 68 Rd HCS (fact 428), 68 Ac Bl Mustang GT Cnvrt, 68 Ylw GT500KR Cnvrt, 68 Hlnd Grn GT500KR Cnvrt, 68 Gld G.T. 500 Cnvrt, 68 Ryl Maroon Mustang Sprint Cpe, 68.5 Hlnd Grn Fstbck, 68.5 Ylw Mustang Fstbck. Visit my website www.scottfullerreproductions.com
Offline TLea
« Reply #9 on: November 09, 2011, 06:49:02 PM »
Scott
I think it was your turn to watch me Scott   ;D
