Author Topic: Early 65 Dearborn inside the trunk pictures  (Read 7576 times)
Offline jtfx6552
« on: October 26, 2011, 10:11:19 PM »
Anyone have some pictures of the undercoating/sound deadener, inside the trunk on an early 65 model year dearborn car? Mine is date code 29K (Oct'64).
I'd love to see some pictures of what it looked like in there.
Also pictures of the seam sealer around the taillight panel and bumper supports would be helpful as well.
JT
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
Re: Early 65 Dearborn inside the trunk pictures
« Reply #1 on: October 26, 2011, 11:21:58 PM »
If you give me until next week I have a Sept 28 Fastback I can post some pictures. The tunk has not been restored.
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
« Reply #2 on: October 26, 2011, 11:52:04 PM »
Here is one example from around that time period. Body style IMHO should not make a great difference
Did highlight the pattern on a couple of pictures to help out - at least where it looks to travel to me ;)
Not a well defined sound deadener pattern on the quarters and the seam sealer allot thinner and neater that other periods and plants
Quarter panel
Taillight panel to lower rear panel
Taillight panel and bumper support
Rear wheel tubs to floor
Offline jtfx6552
« Reply #3 on: October 31, 2011, 11:30:29 PM »
Sounds good, looking forward to it.
Offline jtfx6552
« Reply #4 on: October 31, 2011, 11:32:28 PM »
Quarter panel
Thanks!
The hightlighting is nice as it is hard to see. Can you tell n the 1/4s, does the edge of the undercoating stop before it gets to the outer wheel house? Is there any undercoating overspray on the outer wheelhouse?
« Reply #5 on: November 01, 2011, 01:06:12 AM »
Thanks!
Sound deadener stops  (typically and on the example) before the wheel house and no overspray  on the wheel house
The sound deadener normally does not produce much of an overspray like paint did - its at allot heavier and normally applied just abut 90 degree to the surface in this application
Offline rodster
« Reply #6 on: November 01, 2011, 08:06:23 PM »
Don't know if this is typical but it appears sound deadener was sprayed between the fender and wheelhouse with a bit of deadener on both.
65 Dearborn April 19th build date
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline rodster
« Reply #7 on: November 01, 2011, 08:10:05 PM »
Same car and there are some runs in the paint of the outer wheelhouse.  Possibly from when the wheelhouse was painted?
1984 SVO - 2A
« Reply #8 on: November 01, 2011, 08:58:23 PM »
Those runs are pretty typical at at least a couple of plants. Never cut through them (should) to see if that is a primer run or a paint run which would give us an idea of when that was done and why it happened.
Offline rodster
« Reply #9 on: November 01, 2011, 09:06:45 PM »
I'll get on that tomorrow. ;)  From what I could tell it appeared to be a black paint run but I'll pull one off and cut through it to confirm.
1984 SVO - 2A
« Reply #10 on: November 01, 2011, 09:37:48 PM »
If its in the paint (my guess also) then I would guess that we are looking at the body being tilted after the body was sprayed, as it moved from station to station (or to or in the ovens)
Offline rodster
« Reply #11 on: November 01, 2011, 10:19:19 PM »
Paint runs on the DS too.   Think these paint runs had to come from the trunk area being painted? The must have been pretty heavy on the paint on this car as there are other runs on it too.
1984 SVO - 2A
Offline rodster
« Reply #12 on: November 04, 2011, 12:26:19 AM »
I was wrong about my guess that it was a paint run....ends up it's a primer run with a thin coat of black over it.
1984 SVO - 2A
« Reply #13 on: November 04, 2011, 12:54:05 AM »
Those runs, when present, are typically coming from the bottom up... which means the car was turned up somehow during part of the priming process.
Offline Skyway65
  • Gold Level Subscriber
« Reply #14 on: November 04, 2011, 07:01:02 PM »
Here is a picture of the inside of the trunk of a pre-production Mustang VIN #4, build date code 5C.  I can't vouch for the originality of the sound deadener but I do know the quarter is original to the car so I would assume the sound deadener is original as well.
Gary Schweitzer
MCA #00181
Traverse City, MI
