Author Topic: Center Gauge Console Wiring Harness  (Read 2121 times)
« on: October 17, 2011, 09:32:45 PM »
I just refurbished a 71-73 center gauge console wiring harness and built a duplicate for someone else based upon the original.  The light bulb housings are very unique and could not be duplicated, but the two wire 65 dash cluster bulb housing using an 1895 bulb fits nicely with the same illumination intensity.  The original bulb housings are easily damaged as it isn't clear how to remove them; when one does remove them, the tabs often break off.
I was kinda surprised about how "cheap" the console housing was...basically two shells of plastic.
Offline c9zx
Re: Center Gauge Console Wiring Harness
« Reply #1 on: October 17, 2011, 10:07:07 PM »
The Dash bezels in general appear to have been design for "one time use" only. If a wrench gets within 1/2 inch of a fastener or a finger approaches a bulb socket you hear the distinctive sound of plastic breaking.  Chuck
Thanks, Chuck
1969 G code Cougar Eliminator
CSX 7031
Offline nham3407
« Reply #2 on: October 19, 2011, 10:31:32 AM »
Midlife,
Do you have any plans to start working on 71-73 harnesses any time soon.  I have my complete harness out of the car from end to end and need to go through it just to make sure everything is in good condition and will not cause any problems in a concourse restoration.  I would be very interested if you are looking to move into this era of mustangs.
Thank you,
Brian D.
67 GT S-Code, San Jose, 06/67
72 Mach 1, Dearborn, 01/72
« Reply #3 on: October 19, 2011, 09:18:31 PM »
Who said I didn't do 71-73s?  I most certainly do, and would love to work on yours.  For whatever reasons, the 71-73's appear to be much less butchered than earlier models (is it because it is so difficult to access the wiring?), but they still have problems with pins that need to be re-crimped.
Offline nham3407
« Reply #4 on: October 26, 2011, 05:06:37 PM »
No one said you did not, I guess it was just my wrongly placed assumption.  I will PM you so we can exchange in a bit more in depth.
