Author Topic: Original Shocks, 66 Convertible  (Read 1874 times)
Offline trucktricksdon
    • Direction Auto & Truck Accessories
« on: October 16, 2011, 01:51:37 PM »
Was wondering which brand of shocks were used on a 66 Dearborn car. The ones I took off were stamped "Monroe" with load ratings stamped in them. The front shocks were stamped "C3F8" and the rears were stamped "C5A9". A few questions...could these be the original shocks? If so, what color were they originally? Were there any markings, stickers, logos, paint daubs, etc? Not sure if I should replace them or repaint and restore these. They seem to be ok, no leaks etc.
Re: Original Shocks, 66 Convertible
« Reply #1 on: October 16, 2011, 03:05:48 PM »
Don't believe Monroe was an OEM supplier back then.  Not even sure if they were making shocks in the 60's?
At least one OEM brand I know of is Gabriel.  These have a 'G' insignia stamped into the side.
OEM shocks for 65-66 should have a Ford engineering number and a date stamp.  Something like C4ZF...  5AB.
Original color of 65-66 mustang front/rear shocks was semi-gloss black.
« Reply #2 on: October 16, 2011, 04:16:07 PM »
I thought the same thing but the C3F8 and C5A9 stampings in them are what threw me (they kind of resemble a Ford part number prefix). Maybe it is common for an aftermarket supplier to use part numbers resembling Ford numbers. Any idea what a good replacement would be to closely resemble an OEM?
« Reply #3 on: October 16, 2011, 05:08:51 PM »
Most likely is just a coincidence that the numbers start with C3 and C5.
Not sure what a good replacement is.  Probably be ok with most any of them, just paint black.  Of course, if you show the car, will need to fill/putty in any non-OEM markings that might stand out.
« Reply #4 on: October 16, 2011, 08:35:12 PM »
Thanks for the info
