Author Topic: Inline PDF files *NEW*....Make that coming soon...........  (Read 1232 times)
Offline Sluggo
  • Dark Overlord
« on: October 12, 2011, 02:15:03 AM »
The add pdf button in the post editor is not working properly but it will after I update the forum software later this week.
For now you can post PDF files by simply enclosing them in bbc brackets. Depending on your version of Adobe, they will act just like you are used to. For instance hovering your mouse near the bottom will allow you to save, print, zoom, etc.
Code: [Select]
[pdf]urltoyourfile[/pdf]
<a href="http://www.stangfix.com/images/sum-m08040-41.pdf" target="_blank">http://www.stangfix.com/images/sum-m08040-41.pdf</a><a href="http://www.stangfix.com/images/camchoice.pdf" target="_blank">http://www.stangfix.com/images/camchoice.pdf</a>]
« Last Edit: October 12, 2011, 02:33:45 AM by Sluggo »
MCA 55330 | 69 Mach1 | 427 Stroker | 29 Model A Murray Town Car | 4 Banger
Offline Sluggo
  • Dark Overlord
Re: *NEW* Inline PDF files *NEW*
« Reply #1 on: October 12, 2011, 02:24:25 AM »
Code: [Select]
I noticed that if you modify the post after it's been posted the file show in the edit screen just like in the post. The tags call a command that displays the file.
if you edit the post the absolute link is shown instead of the file. I have a feeling it will do the same with this quoted reply as well.
This anomaly will also be fixed in the update. I've already tested it on another site and it works famously.
« Last Edit: October 12, 2011, 02:26:30 AM by Sluggo »
Offline Sluggo
  • Dark Overlord
« Reply #2 on: October 12, 2011, 02:30:02 AM »
Well.......................
The quoted post wiped out the pdfs displayed in the first post after I submitted it.
I went back and removed the links from the second post and and the files re-appeared in the first post.
This is a little too buggy for me. I will remove it until the update is done. It will be worth the wait.
Re: Inline PDF files *NEW*....Make that coming soon...........
« Reply #3 on: October 12, 2011, 08:58:12 AM »
Thanks Randy!
