Author Topic: Floor Pan to Rocker Sealer  (Read 1784 times)
Offline Alpha1946
« on: October 10, 2011, 09:41:48 PM »
For a vehicle built in Dearborn in June of 1964 what color sealer would be used for sealing floor pan to rockers?  If someone has a brand name and part number it would be helpful.
64.5 Wimbledon White Convertible
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
Offline Ivygreen65
Re: Floor Pan to Rocker Sealer
« Reply #1 on: October 10, 2011, 10:37:07 PM »
What I have seen is a black, bituminous type of sealer applied in a bead approximately .375" - .50" thick.
« Reply #2 on: October 11, 2011, 12:58:34 AM »
Normally see a black sealant that was applied with a chalking gun then spread to about 1/2" wide as mentioned
I've been using a non textured black elastomeric  sealant I get at local home improvement stores, spread with a 1/2" throw away paint brush that I've cut all the bristles from (except for the last 1/4" then dipped in water or thinner.
This is applied after the floor has been painted not before
Offline Alpha1946
« Reply #3 on: October 14, 2011, 11:45:26 AM »
Thanks for your help
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
Offline lpsmith10212
« Reply #4 on: November 06, 2011, 11:51:27 AM »
Try your local automotive paint store 3M OR PPG makes one.
