Author Topic: 67 Dearborn Plant buck tag?  (Read 3304 times)
« on: October 06, 2011, 07:33:16 PM »
Pictured below is a tag I removed from the radiator support from a Dearborn built junkyard car.  It has the VIN plus a few other items:
1. 63B (it is a 2+2 with the interior decor option)
2. I (body is lime metallic color)
3. 419
4. 6A (it does have a black interior)
5. EXT (it does have exterior decor option)
6. RM (remote mirror? doors long gone)
I presume that the 419 is some sort of rotation number.
Also observe the the rear which is a (faded) door tag.  The holes, one of which was used to attach it to the radiator support near the pass side horn, line up with where the door tag would have been riveted if used for that purpose.  It was mounted with a single phillips body screw, one with the disproportionately large head.   The screw would not budge so the tag was ripped off.
Re: 67 Dearborn Plant buck tag?
« Reply #1 on: October 06, 2011, 10:44:10 PM »
Nice find - and yes sometimes it appears they used door tags (with the warranty part still attached) think I've got a couple in my buck tag box as well as some in pictures
According to the research Kevin Marti did and his work published in "The Mustang and Cougar Tagbook"
your right about the EXT but for 67 Dearborn (codes could differ between years and plants) the RM meant Rocker moldings
Offline 68 S Code
« Reply #2 on: October 07, 2011, 01:05:44 AM »
Did Dearborn tags not have the punched symbols I've seen on some NJ built 68 tags?
« Reply #3 on: October 07, 2011, 09:13:21 AM »
I'm sure that question was for an expert like Jeff and not me.  However, I can add a picture of a 1968 15k mile NJ car with two symbols, a star and a "fish".  The Dearborn one I have has no punched symbol, with the exception perhaps over the EXT text.   Some of that material is missing.
I'm interested in how the tag became body color way up front.  The back has absolutely no indication of overspray.  The front has some black and it looks like the black was roughly masked off when sprayed.
I'll take a closer look at the car next week, John
« Reply #4 on: October 07, 2011, 07:21:08 PM »
We see pressed into tag inspector (IMHO) stamps but not punch symbols
Another example of - different plant = different practices
Looking at other 67-68 Dearborn buck tags I have pictures of  are door tags  used for this purpose
Offline rodster
« Reply #5 on: October 10, 2011, 11:02:17 PM »
Has anyone ever seen a tag like this?  It's punched with some numbers/letters like a buck tag. There is a tag on the DS and the PS cowl under the sealant.
Dearborn car.
Yep Seen them ;)
« Last Edit: October 11, 2011, 12:37:01 AM by J_Speegle »
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline bastille_stango
« Reply #6 on: September 27, 2015, 07:16:53 AM »
(newbie reading old threads ... sorry if not relevant anymore !)
Same for 1968 Dearborn :
8F02J 63B T5 6A 25C 89 G W
TW PB GT CL FDS PS "Caroline"
« Reply #7 on: September 27, 2015, 08:38:34 AM »
It looks like a nicely equipped car.
« Reply #8 on: September 27, 2015, 10:36:53 AM »
 :D ThanX ! Almost full option in deed ... (except for headrest, molding, rear defog, console and AC)
DSO 89 Transportation Services + Company lease plan =  probably ordered by so working/retiring from Ford !?
