Author Topic: Wiring for Fuel Sending Unit?  (Read 1711 times)
Offline Andrew@MagMustangs
    • MagMustangs
« on: September 26, 2011, 01:43:49 PM »
In 67-68 was there a difference in the Trunk Hole Location where the wiring feeds through the Trunk Floor for Single or Dual Exhaust Cars? Middle-Front of Trunk vs. RH Side Hole? Or did all 67-68s go through the Rh Side? Thanks, Andrew
Re: Wiring for Fuel Sending Unit?
« Reply #1 on: September 26, 2011, 04:24:00 PM »
Only seen them go through the passenger side trunk floor.  Only cars I have seen that don't follow that pattern were easily recognizable as having sheet metal replacement in the rear.
Offline gtamustang
  • CPM
« Reply #2 on: September 26, 2011, 04:55:39 PM »
As Charles has stated, all 67-68 fuel sending pigtails went through the rh trunk floor pan in the same location (same size hole in same location).
Regards,
Pete Morgan
    • MagMustangs
« Reply #3 on: September 26, 2011, 05:27:41 PM »
Thanks!!! It seems 69-70 had this difference between Single and Dual Exhaust Cars, and I wasn't sure if 67-68 had that same difference. Thanks Charles and Pete.
