Author Topic: Voltage regulator Color  (Read 2614 times)
Offline Stangly
  • Gold Level Subscriber
« on: September 25, 2011, 10:57:12 PM »
I cleaned up my voltage regulator and it appears to have black paint on the inside and outside of the cover.  I have seen pictures of similar cars that are blue.  I was wondering what the correct color would be for a 69 Dearborn car 302 2V 3  speed automatic.
68 Coupe J-Code
2001 V6 Laser Red
2015 GT Deep Impact Blue
Re: Voltage regulator Color
« Reply #1 on: September 26, 2011, 06:39:16 PM »
Blue .The black was discontinued sometime in very late 67 production from what I have seen. If black the most likely explanation is that it was a earlier transplant. Maybe old service stock . Bob
Offline Stangly
« Reply #2 on: September 26, 2011, 08:46:05 PM »
Thank you Bob!
68 Coupe J-Code
2001 V6 Laser Red
Offline Stangly
« Reply #3 on: September 27, 2011, 07:18:19 PM »
Bob,
Any references on companies to purchase a good concours voltage regulator,starter solenoid, and distributor cap.
68 Coupe J-Code
2001 V6 Laser Red
« Reply #4 on: September 27, 2011, 07:24:44 PM »
Bob,
IF your looking for reproductions I don't think you have many options - think there is only one provider for each.  Though many shops carry them
Offline Stangly
« Reply #5 on: September 27, 2011, 09:51:17 PM »
NPD is showing three different Autolite starter solenoid models for 67-72 they refer to different script codes REPCO,RBM and a plain Autolite, not sure what the difference is.  VA Classic shows just one model.  They are all priced about the same; few bucks difference.  Is it prudent to find and use used ignition parts or should I stick with NOS or reproductions.
Thanks again everybody for the help,
68 Coupe J-Code
2001 V6 Laser Red
« Reply #6 on: September 27, 2011, 11:31:06 PM »
The one your looking for would be the standard style (not sure if anyone is making the heavy duty ones) marked AUTOLITE  - C7.....
Offline Stangly
« Reply #7 on: September 28, 2011, 08:43:38 AM »
Thanks Jeff!
68 Coupe J-Code
2001 V6 Laser Red
