The 67 that I posted the picture of the canister under the battery also has the AC can under the RH hinge.
Marty, on this "two-can" example, you have posted the picture of, do you recall how the vacuum hoses were all routed?
I ask this while looking at the chassis assembly manual for the steering column as reference. (pages 46 & 47 and also pages 6 thru 8 )
I would assume they connect individually to the manifold, but since both style canister routing's are not on the same pages in the manual, it gets confusing. For example, NOTICE that at the top of page 6,7 or 8 of the assembly manual (choose according to engine size), at the center of the page, there is a "T" 3E563 that seems to show to go to the "TILT SWING COLUMN" and that "T" looks to be INSIDE the cowl, under the dash, on the supply hose coming from the oblong reservoir.
This adds to the confusion because the notes on page 46 and 47 (bottom left of page) state what has previously been mentioned, "VACUUM LINES MUST NOT BE TAPPED INTO FOR OTHER USES".
I believe that I should plan on doing this correctly, that is with both cans. It would be nice to set it up correctly the FIRST time and not need to redo it.
Besides the green with white hoses that seem to not be reproduced just yet, it looks like I would need the following:
* one (1) 3E649 bracket
* two (2) 55981-S2 screw bolts (to battery tray)
<AMK SELLS these in multi-packs>* two (2) 34657-S2 nuts, resevoir to bracket
<AMK doesn't seem to handle these, LOCATED>
* two (2) 3A762 hose clips (that clip to the right strut support )
<AMK doesn't seem to handle these, HELP WANTED>
* one (1) 378569-S hose clip (that holds hoses to the apron, below battery)
<AMK doesn't seem to handle these, HELP WANTED>* one (1) 19A563 check valve, single port in, single port out
PLEASE, double check the assembly manuals and check my information and part numbers. It might help to get AMK or complete OEM part numbers too if anyone can help. I believe I already have the hose hanger on the cowl, 357064-S and the resevoir 3E547, so the search is ON for these other items.
Previously, my tilt was operated using the oblong AC canister, but I made all the hose connections several years back to get the tilt-away functioning. (it had been disconnected by P.O. for vacuum leaks) At that time, I was only after "function", not seeking the likes of "concours" in presentation. Nothing was as it should be since I had no information on this system or other examples as reference. Hence all these questions. I know how to make it "work", I am after a correct installation for my time period at San Jose, for a car with a 289 engine and has AC.
One more question, Does anybody know if the hose clip at the battery is the same or similar to the clips used for the wiring harness in that same area? A detailed picture of an unmolested might help some here.
Richard
