Author Topic: Styled steel wheel trim rings  (Read 2432 times)
Offline 68 S Code
« on: September 15, 2011, 12:32:01 AM »
Painting wheels over the weekend so decoded to clean up trim
Rings and caps. Noticed that of the 9 trim rings I have 2 are very shiney on the tapered wall. Just as bright as the outer edge. The other 7 are more satin in appearance with a bright outer edge. Did someone in the past polish the Satin out on two of them or did chrome Wheels get a brighter trim ring?
Re: Styled steel wheel trim rings
« Reply #1 on: September 15, 2011, 09:28:53 AM »
The satin ones are 68 only. The bright could be 67 or 69. Good satin ones are hard to find. Marty
Offline 68 S Code
« Reply #2 on: September 15, 2011, 09:59:51 AM »
Marty thanks for confirming. I had a feeling that the shiney one would be off with the argent wheels. I hope can find 4 nice ones out of the 7 satin/ brushed left.
« Reply #3 on: September 15, 2011, 10:11:27 AM »
They're stainless steel, so you could always tone down a shiny one to make a satin one.
Offline 68 S Code
« Reply #4 on: September 15, 2011, 11:24:32 PM »
How would I get the brushed look to make it satin? Right now out of the 7 satin I have 3 which should clean up ok. One of the shiney ones are nice but too bright.
« Reply #5 on: September 16, 2011, 02:10:24 AM »
2000 or 2500 sandpaper, wet sand and keep the paper straight so the lines are even.
Offline 68 S Code
« Reply #6 on: September 16, 2011, 09:16:09 AM »
Is it possible to tap out a small ding in the tapered portion so it doesn't look like a repair? Thanks for the technique.
« Reply #7 on: September 16, 2011, 12:08:33 PM »
If you can get to the area behind the ding, should be able to tap it out.
Offline 68 S Code
« Reply #8 on: September 16, 2011, 11:07:19 PM »
Thanks. Finished painting the wheels today and after stripping off the tape I think they came out pretty good. Now all I need to do is add the daub on the back. Ready for tires, trim rings and caps.
Offline sportyworty
« Reply #9 on: September 23, 2011, 02:08:33 AM »
When refinishing the brushed center on the trim rings it is easier to get a straight line finish by installing the wheels. You can spin the wheels while holding the abrasive of choice in place. Saves a lot of time and gives a better finish.
Offline 68 S Code
« Reply #10 on: September 23, 2011, 09:02:57 PM »
I wonder how it would work on a tire balancing machine?
