Author Topic: Red P decal  (Read 4747 times)
Offline Panther
  • Bronze Level Subscriber
    • Early Mustang
Red P decal
« on: September 14, 2011, 04:23:04 AM »
A few weeks ago i've seen a 65 mustang with a red P decal in the engine bay (on the fender on the passengers side). Unfortunately i don't remember the assembly line nor the VIN (but could check it this weekend).
The decal looked like this one:
I've already read that it is either a PAINT OK decal or an overall inspection mark. What is right and when or on what cars was this decal used?
I don't remember it exactly but i think the car i looked at was unrestored or thoroughbred. At least very original.
Paul
6R07C214274
65A 8 D6 11F 71 6 6
Certified MCA Judge 1964.5-1966
Re: Red P decal
« Reply #1 on: September 14, 2011, 06:02:47 PM »
Typical of Dearborn to use those on the firewall/cowl.
Offline Ivygreen65
Re: Red P decal
« Reply #2 on: September 14, 2011, 06:23:18 PM »
I have seen original P decals in black, but not in red.  Has anyone seen an original decal in red on a 65/66 car?
Re: Red P decal
« Reply #3 on: September 14, 2011, 06:34:22 PM »
Yep
Offline Panther
    • Early Mustang
Re: Red P decal
« Reply #4 on: September 14, 2011, 06:41:50 PM »
Thanks Charles, this helps a lot!
Have you seen this decal in other positions or only on the firewall/cowl area?
This weekend I'll talk to the owner, perhaps i can bring up more infos about the car then.
Thanks again!
Paul
6R07C214274
65A 8 D6 11F 71 6 6
Re: Red P decal
« Reply #5 on: September 14, 2011, 07:48:18 PM »
Only seen it on the cowl for 65-66 Dearborn.  If you buy the replacement ones, they probably should be trimmed down a little.
Offline NEFaurora
Re: Red P decal
« Reply #6 on: September 14, 2011, 08:43:53 PM »
Here's some from two of Bob Perkin's super low mile original cars..
*Also, Charles mentioned cutting down the repros...I have noticed that the originals are always square, but the repros have rounded ends..which I have never seen on an original car ever.. Note original location of the "P".  This is where it is usually found on a Dearborn car, but in reality, It could have been found anywhere on the top cowl..
Tony K.
MCA#70001
Offline NEFaurora
Re: Red P decal
« Reply #7 on: September 14, 2011, 08:49:05 PM »
Almost forgot to mention, These are both 1966 Dearborn cars.  The first a black '66 hardtop (56 original miles- Literally, a new car time capsule), the 2nd, a Black '66 Fastback (Not sure of the orignal miles, but they are super low also).
Tony K.
MCA#70001
Re: Red P decal
« Reply #8 on: September 14, 2011, 11:14:19 PM »
HAve examples on Dearborn cars of red and black "P"s up into 70 (later ones with the inspectors names printed/stamped on than. Typical on cars after the ink stamps were done away with at that plant for some reason
Offline NEFaurora
Re: Red P decal
« Reply #9 on: September 15, 2011, 07:44:49 AM »
Jeff, So, though one should never "assume" anything in the mustang universe.  Are we to assume the Paper, The "P" stands for "Paint-OK", The "F" stands for "Final-OK", and I think that there was an "N", and "K", also right?   I have no idea what those stand for!
-So a car with these paper decals should not have paint or ink stamps is what you are saying..Makes sense...Never really thought about that before..
Tony K.
MCA#70001
Offline Panther
    • Early Mustang
Re: Red P decal
« Reply #10 on: September 15, 2011, 03:43:56 PM »
Great pictures, thanks!
I will check whether the P stamp is a repro. I'm quite excited to find it out ;)
@Tony: I think the other letters were F B T, weren't they?
I read on VMF that it shall mean: F - Final ; B - Body ; T - Trim.
Is this right?
Paul
6R07C214274
65A 8 D6 11F 71 6 6
Offline NEFaurora
Re: Red P decal
« Reply #11 on: September 15, 2011, 09:07:13 PM »
Yes, You are right.. The other two were "B", and "T"... I could not remember the last two by memory..  :o(
Thanks for the addition.. so there were 4- "P", "F", "B" and "T".
MCA#70001
Re: Red P decal
« Reply #12 on: September 15, 2011, 11:16:30 PM »
There were many different "letter" stickers if you include all the years - always got to be careful ;)
Offline NEFaurora
Re: Red P decal
« Reply #13 on: September 16, 2011, 11:21:05 AM »
Pretty much just dealing with '65/'66 above Jeff..
Noone has asked the question, Was the Red "P" used after '66 ???
All I've ever seen after '66 are Black ones..
Tony K.
MCA#70001
Re: Red P decal
« Reply #14 on: September 16, 2011, 01:55:29 PM »
Yes have examples of the use of red "P"s through 1969 Dearborn and other non Mustang plants.  Example - in 69 you will typically see them (on Mustangs) in the drivers side door jamb - a pillar - near or slightly under the  weatherstrip
