Hello! At the risk or being told to look elsewhere, I will wade into the much discussed "what is the correct color for my engine?".
Of course I've read a few threads on engine colors here. Very good stuff. However its a little more complicated down here in Australia as we don't have access to products like Plastikote 224 and even the USA PPG codes don't always translate into the local stock well. Likewise the Duplicolor DE 1621 is hard to find here too (although the brand itself does exist in OZ). My reading so far, has convinced me that my 68' does not use the darker 69' onwards paint, nor the very light blue seen on some early 60's ford engines. True? Please correct me if not the case.
So anyway I bought 3 shades of locally available VHT Ford engine paint (Ford COMP Blue, OLD Ford blue and NEW Ford blue), and tested them on some sheet metal, then compared them to some aged original looking paint remnants on my block AND a spare 68' block I had lying around. The closest of these by far, was "OLD FORD BLUE" (VHT code SP153). I noted that that name has been applied to a couple of other manufacturers offerings, including the often suggested Plastikote 224 and Duplicolor 1621 . The VHT Old Ford Blue (SP153) looks very close to the Duplicolor 1621 in one attachment I posted here. Which gave me some hope that its OK.
Unfortunately I find my iPhone camera's photos only shows up poorly on the web, so not a lot of use posting them up. However I have attached 2 head photos using VHT OLD FORD BLUE, and the POR chart.
Anyway after all that I was then told they were ALL wrong, you need the POR15 engine paint "Ford Corporate Blue". Great. :-)
So with some hassle and expense I bought some and sprayed my water pump, timing cover and thermostat housing. The paint itself leaves a lovely finish, (albeit its not as forgiving as VHT rattle cans), but I cant help thinking its just too dark! To complicate matters a new Scott Drake 67' air cleaner I have on the shelf is another color again! And I understand the 67' & 68' engines are the same colour? Is Scott Drake right with their colour? (I mean to say, they aren't exactly known for always being dead nuts on). Its a different shade from any of the colors I've seen touted as being correct. As an aside, should the air cleaner base and its engine be the same shade of blue? Always seems to be that way when I see other 68' cars.
So has anyone here tried that POR15 paint? Opinions? Based on the web photos of parts painted with DE1621 I can't help thinking the VHT Old Ford Blue is pretty close for my March 68' S code's engine.
I've also noted a few photos of finished 67 / 68 S code engine bays like the one attached, that seem pretty close to the Old Ford Blue...
