Ok, I have read so many posts regarding this but I want to make sure once and for all I have the correct color before I do the work. I only have access to Duplicolor product so I need to know what one do I use. Is it DE1621 Old Ford Blue, DE1601 Ford Blue or DE1606 Ford Dark Blue? The notes below are from Mustang Monthly and now I am really confused.
Thanks for your help......
For many years prior to 1966, Ford engines were color-keyed to specific applications and carlines. For 1966, this practice changed, when all Ford engines were painted Ford Corporate Blue. Instead of color-keyed valve covers and air cleaners, the entire engine would be Ford Blue, like the Ford Blue Oval and the Ford Blue offset dealer signs popping up in 1966. Ford's message for 1966 and beyond was simple-if it is blue, it is power by Ford.
As in 1964-'65, Ford continued to paint the valve covers separate from the engines. Engine long-blocks, which included block, intake manifold, heads, and oil pan, were all painted Ford Blue, a darker blue that covered all hardware except the valve-cover bolts. Valve covers were installed toward the end of engine assembly using natural metal bolts with integral lock washers. We've learned through observation and conversation with restorers that Duplicolor's Dark Ford Blue (1606) is an accepted color for '66 and later Ford engine restorations. An alternative, when Duplicolor isn't available, is Krylon's Dark Ford Blue, which is also the correct shade of dark blue. Plastikote is another paint brand, Royal Blue (1134) an acceptable color for '66 and later
And again from another source......
There are 3 different blues that have been used ...
Light blue - a.k.a. Old Ford Blue
1963 (some applications) - 1965
Duplicolor DE 1601 (Ford Blue)
Corporate Ford Blue
1966-1968
Orig Ford PN: EP-2075-C
Duplicolor DE 1621 (Old Ford Blue)
PPG DAR 13358
Ford Blue
1969-1981
Duplicolor DE 1606 (Ford Dark Blue)
TRW #630224
Eastwood's "Dark Ford Blue."
Thanks, Jeff
