Author Topic: Convertible Top Motor Fluid  (Read 6054 times)
Offline Skyway65
  • Gold Level Subscriber
« on: August 26, 2011, 08:19:20 AM »
This question has been asked before but I can't find a definite answer-so I'll ask it again. What fluid do I use for the power top on a '65?  The manual calls for Type A transmission fluid. The original fluid I drained from my car's system was clear.  Some have recommended using Type F or Mercon fluid.  What will work as I get this back together; the top goes on next week.  :D TIA
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline Twilight65
Re: Convertible Top Motor Fluid
« Reply #1 on: August 26, 2011, 09:41:19 AM »
Gary,
I was going to use Dextron III ATF fluid in mine from what research I've done.
Dave
« Reply #2 on: August 26, 2011, 10:03:46 AM »
Most use Type F.
Offline Skyway65
« Reply #3 on: August 26, 2011, 10:20:55 AM »
thanks for the quick replies-that's what I'll be working on today  ;)
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline buckeyeresto
« Reply #4 on: August 27, 2011, 03:56:51 PM »
fluid for snowplows works about the best, its clear and no freeze
Offline 68 S Code
« Reply #6 on: September 06, 2011, 07:50:51 PM »
You should use type F fluid. I recommend NAPA brand as it's viscosity is a bit higher and it will not seep past seals as easily as a less cuscus fluid. Some say you can use brake fluid but that sounds like a disaster waiting to happen.
Offline NEFaurora
« Reply #7 on: September 10, 2011, 10:30:20 AM »
Got to disagree here... I did lots of research on this one.
You should go with Dexron Mercon...even though the original was Type "F".  It seems that the Type "F" will eat the rubber seals over time, where the Dexron Mercon will not. Both do the same job. The Type "F" has properties in it which do not like rubber...
I vote Dexron Mercon....Which is what I have in my pump.. Works perfect.. I would suppose this is the reason that they went away from the Type "F" fluid over the years, but I am not a chemist obviously.
MCA#70001
