Author Topic: Traction Master  (Read 939 times)
Offline MWM
Traction Master
« on: August 08, 2011, 07:30:33 PM »
When I purchased my car, it had a set of Traction Master bars.  These are mounted underneath the car.  On the front trailing arm, there is an L bracket welded to the car with a LOT of WASHERS between the inside of the L Bracket and the bar.  Is this correct?  I would have thought that there would have been a U Channel at least with a few less washers...
Thanks!
Re: Traction Master
« Reply #1 on: August 08, 2011, 08:10:08 PM »
When I purchased my car, it had a set of Traction Master bars.  These are mounted underneath the car.  On the front trailing arm, there is an L bracket welded to the car with a LOT of WASHERS between the inside of the L Bracket and the bar.  Is this correct? ............
Is that typical (in an effort to line up the brackets inline)? Yes
