Author Topic: '65 Trunk lock sleeve removal  (Read 1451 times)
Offline C5ZZKGT
  • Gold Level Subscriber
« on: August 08, 2011, 10:27:48 AM »
I'm trying to replace a trunk lock sleeve (the outside chrome part) I have removed the assembly from the trunk lid and cannot figure out how to remove the lock cylinder itself to transfer to the new chrome sleeve-any suggestions??  Thanks!!
Re: '65 Trunk lock sleeve removal
« Reply #1 on: August 08, 2011, 10:29:38 AM »
iirc there is a sunken pin that needs to be depressed. look it over and i believe you will find it..
« Reply #2 on: August 08, 2011, 12:12:25 PM »
Fred is right, there's a pin that you have to push down on to release the lock cylinder.
Offline C5ZZKGT
« Reply #3 on: August 09, 2011, 09:30:13 AM »
Guys, Thanks!! I've got it in front of me here and I'm seeing a small round pin looking thing on one side and a ring looking thing on the other side, I've tried putting a little pressure on the round pin and no movement-do I need to tap on it with a punch or something?? -looks so simple.........
« Reply #4 on: August 09, 2011, 10:27:02 AM »
the pin is spring loaded. put the key in & turn while pushing down.
Offline C5ZZKGT
« Reply #5 on: August 09, 2011, 12:23:28 PM »
Ahhhhhhhh, I will try that then advise, Thanks Again!!
