Author Topic: Sprint 200 A/C Compressor  (Read 3134 times)
Offline Pete Bush
« on: August 07, 2011, 08:08:37 PM »
Would the A/C compressor on a '66 Sprint have a double groove pulley, even though only one was used? Anyone have pictures of a 6 cylinder application?
Offline Pete Bush
Re: Sprint 200 A/C Compressor
« Reply #1 on: August 08, 2011, 06:42:45 AM »
I found an illustration in my 1966 Electrical Assembly Manual page 53. It shows two different clutch assembly applications: The first looks like a single groove Pitts Clutch Assembly; the other looks like  a double groove Warner Clutch Assembly. Would the Pitts clutch have been used for installations without power steering, and the Warner clutch for those with power steering?
« Reply #2 on: August 08, 2011, 08:23:52 PM »
Looking at the pictures I would say no dual pulley
Examples
Appears to have been replaced
May have been replaced
Low mileage original
Offline Richard P.
« Reply #3 on: August 08, 2011, 09:55:45 PM »
It has been sometime ago but, I worked on a 1965 Mustang 6 Cly with AC and I think the clutch was a dual grove pulley on the compressor. I'd check with Classic Auto Air. I'm sure they can be of help.
Offline Pete Bush
« Reply #4 on: August 09, 2011, 07:11:57 AM »
Offline kevin1221
« Reply #5 on: August 10, 2011, 03:09:24 PM »
Pete:
My 66 Sprint also has a single pulley on the compressor.
Kevin
« Last Edit: August 10, 2011, 03:12:09 PM by kevin1221 »
Kevin
Tampa FL
1966 Mustang Sprint 200ci Six - Automatic
Scheduled Build date : 7-7-66 - Dearborn
MCA Concourse Gold winner (Multiple)
MCA Conservator Award
AACA Sr Grand National 1st (Repeat)
Currently own 2008 Shelby GT
Offline tnguy624
« Reply #6 on: August 10, 2011, 04:16:38 PM »
Thanks for the info, I am the guy with Sprint, that Pete was searching about the compressor pulley.
The reason I was wondering, was my Mustang Restoration Manual, showed three types of pulleys and all showed as two belt ones.
Thanks again Pete!  :)
1966 Convertible
Born Jan. 17, 1966 Dearborn
Rebirth began Feb. 2012
Reborn July 2013
1966 Sprint
Born  May 27, 1966  Dearborn
D-4 Interior: Parchment/Emberglo
V    Exterior: Emberglo
Rebirth began March 2009
Reborn May 2011
Moved to Australia Dec. 2011
MCA # 78931
Offline Pete Bush
« Reply #7 on: August 10, 2011, 09:16:18 PM »
Hey Terry,
Glad you finally made it here!  ;) You won't find a better source of info - or a better bunch of folks.
Kevin has a MCA Gold winning Sprint. You can learn allot from studying his pictures.
« Reply #8 on: August 11, 2011, 04:00:20 PM »
If its the book I'm thinking of its because that is pretty much just a reformating of allot of info from the 72 or 75 illustrated parts catalog so it has replacement/service parts info not what was originally used (what Ford was supplying at the time that would fit) ;)
Offline C5ZZ
« Reply #9 on: August 14, 2011, 04:07:07 PM »
I added on factory A/C onto my six and after hunting down
and buying parts I have seen that all the 6 cyl A/C applications
used a two groove clutch pulley whether they had power steering
or not. The belt configuration is different on PS and non PS applications.
My car has power steering so I have a small belt that runs from
the compressor to the alternator. Non PS doesn't use the second
groove on the clutch pulley but goes around the wp and crank pulleys.
MCA # 00945
Rangoon Red/Red Interior
Offline C5ZZ
« Reply #10 on: August 14, 2011, 04:10:54 PM »
Pete:
Kevin
You have a two groove pulley pictured but you
are just using one groove, you must not have
power steering on your car.
MCA # 00945
Offline kevin1221
« Reply #11 on: August 14, 2011, 05:25:45 PM »
Your absolutely correct. I was thinking one thing, and typed another. The car does not have power steering.
Thanks for clarifying.
Kevin
Kevin
Tampa FL
