Author Topic: 64 1/2 trunk floor with drop offs  (Read 3950 times)
Re: 64 1/2 trunk floor with drop offs
« Reply #15 on: August 05, 2011, 09:36:54 PM »
Here is a shot of a typical 65-66 trunk drop off. Don't have one from your car's period and plant but hopefully this will get the discussion going.  All the earlier ones I have were similar.  Sure other 64 1/2 guys can compare theirs and comment
Offline Alpha1946
« Reply #16 on: August 05, 2011, 10:28:40 PM »
Jeff,
Thank you for the picture.  I THINK that we have located a 64 1/2 that I will be able to take pictures off so that we can modify the parts that we have.  Would still like to see someone else's pictures of thier  64 1/2 in case my source doesn't work out.
64.5 Wimbledon White Convertible
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #17 on: August 05, 2011, 10:47:44 PM »
Late June 64 car
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
Offline jtfx6552
« Reply #18 on: August 05, 2011, 11:30:57 PM »
I welded up all the holes in the vertical drop down surface on mine.
Below is a picture of my original (October 64).
The Dynacorn's are short like Bryan said, but at least for me, only a little, maybe 1/4" to 3/8 towards back by the valence. At the wheel opening, they were ok.
I replaced min while the 1/4's were still on so I could see just how short they were. If you look real close at the far left edge of the second picture, you can see where the 1/4 starts to stick below the drop off.
Offline Alpha1946
« Reply #19 on: August 06, 2011, 12:01:54 AM »
Thanks for all the help.
Dearborn June 1964
289
4 speed
76A   M   42   04F   55   1 5
5F08D156472
Offline Dave Stribling
« Reply #20 on: June 13, 2013, 11:53:28 AM »
So just to verify - a 64 1/2 without backup lamps WILL or WILL not have the holes for the backlamp wire from the factory? - Dave
« Reply #21 on: June 13, 2013, 03:48:15 PM »
Yes, no holes in the drop-offs on 64 1/2 as well as 65 without factory back-up lights. They were optional in those years, mandatory from 66 on.
