Author Topic: Carpet install advice  (Read 2174 times)
Offline 68 S Code
« on: August 02, 2011, 09:06:48 AM »
When installing the carpet and screws/seat belt bolts what is the best way to punch holes so as not to wind the material around screws. Ice pick or awl? Thought I read it should be punched from back side but that seems impossible at rocker panels,
Offline TLea
Re: Carpet install advice
« Reply #1 on: August 02, 2011, 09:39:23 AM »
I push a large nail through the hole to mark it then use an old soldering iron to burn hole through
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #2 on: August 02, 2011, 10:34:52 AM »
EGGZACKLY!!!  Only I use a good one, not an old one!  LOL
66 Metuch Conv
Nightmist, Std Blu Int
Offline 68 S Code
« Reply #3 on: August 02, 2011, 06:29:58 PM »
Thanks for the advice. I presume you use the soldering iron to melt the loops to keep them from winding around the screw? Good idea.
Offline TLea
« Reply #4 on: August 02, 2011, 06:38:19 PM »
not only to melt the carpet from fraying but also to make a nice clean hole
Offline bryancobb
  • 2009 Ridn' Around
« Reply #5 on: August 02, 2011, 09:49:15 PM »
NO!
Let the hot tip melt the hole, enlarge the hole, and fuse the yarn so it doesn't unravel.  Don't touch a drill or hole cutter.
66 Metuch Conv
Offline 68 S Code
« Reply #6 on: August 04, 2011, 12:14:47 AM »
Got it.
