Author Topic: '65 Black Grille Rivets  (Read 3118 times)
Offline Skyway65
  • Gold Level Subscriber
« on: July 27, 2011, 08:34:57 PM »
Does anyone have a supplier or part number for the black rivets used on the '65 grille brackets and tabs?
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: '65 Black Grille Rivets
« Reply #1 on: July 27, 2011, 09:05:37 PM »
I think I remember Hanson Rivets having black anodized aluminum rivets.  The ones on the grille are probably steel but how could anyone ever tell?
66 Metuch Conv
Nightmist, Std Blu Int
Offline Skyway65
« Reply #2 on: July 28, 2011, 09:25:13 AM »
...with a magnet? ;D
Thanks Bryan
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline Skyway65
« Reply #3 on: August 04, 2011, 12:25:49 PM »
Well, after some research I discoverred that the original rivets are aluminum and that Hanson only has black steel rivets. (part #C1-5-ST) I ordered a few samples to compare with the originals.
So in the meantime I'm wondering if anyone anyone else has already been down this road and can shed some light on a part number or supplier for the correct rivets?!
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline MWM
« Reply #4 on: August 05, 2011, 03:23:21 PM »
Gary,
I used gun bluing from the local hardware store.  I took several coats, but finally black enough for me.  Make sure you use gloves or your fingers will match too!
« Reply #5 on: August 05, 2011, 08:57:26 PM »
Have used a Sharpie felt tip pen in a pinch
Offline Skyway65
« Reply #6 on: August 06, 2011, 12:26:14 AM »
Thanks guys--Jeff, would that be considered "concours correct?" :D
« Last Edit: August 06, 2011, 08:49:29 AM by Skyway65 »
Gary Schweitzer
MCA #00181
Traverse City, MI
« Reply #7 on: August 06, 2011, 05:53:06 PM »
The restorers job is to present the part or parts that replicate what the item looked like originally. How ever you get there is your choice or secret - ;)  but just one of the reasons we set up this forum - to share those "secrets"
Offline Twilight65
« Reply #8 on: August 06, 2011, 07:58:02 PM »
Gary,
I assembled my grille with rivets from AMK (painted the tabs first) I used a hand hole punch and punched holes in masking tape. Then I put the tape with hole over the head of the rivet and used semi-gloss black paint and sprayed them. Turn out like the real thing.
Dave
Offline Skyway65
« Reply #9 on: August 07, 2011, 10:05:11 AM »
Thanks guys-this is all good stuff.  Without this site many of us would be left scratching our heads trying to reinvent the wheel at every turn. :-\
Gary Schweitzer
MCA #00181
Traverse City, MI
