Author Topic: 69 390 Engine Head Gasket Question  (Read 1985 times)
Offline G Wood
« on: July 19, 2011, 03:37:31 PM »
I am preparing to detail my 390 S Code engine that is currently out of the car. The head gaskets protrude from the block (on the front of the block) approx. 1/4". The gasket is a metal/paper combination. Is the protrusion correct for a Jan Dearborn car?
Re: 69 390 Engine Head Gasket Question
« Reply #1 on: July 19, 2011, 08:33:45 PM »
All along the length of the face or only at the bottom forward corner or that general area?
Offline G Wood
« Reply #2 on: July 19, 2011, 11:33:11 PM »
Jeff:
It is the front facing end of the head (nearest the radiator).
« Reply #3 on: July 20, 2011, 12:52:59 AM »
Don't see an edge sticking out 1/4" the full length on original engines in the pictures I have
Offline G Wood
« Reply #4 on: July 20, 2011, 10:24:33 AM »
Jeff:
Thanks for the information. Do you happen to have a photo, I am uncertain if there should be some gasket or no gasket extending from the head/block.
Regards
« Reply #5 on: July 20, 2011, 07:35:42 PM »
Some examples of what appear to be originals. Sorry hard to find allot of pictures of this detail. So often AC or PS is in the way
Offline G Wood
« Reply #6 on: July 20, 2011, 11:27:39 PM »
Thanks Jeff:
From what I can see it appears to be flush, no gasket protruding.
« Reply #7 on: July 21, 2011, 09:50:40 PM »
Along the flat face - (there is a bit of gasket lower on the assy that can be seen where the head cuts back in towards the block head surface)  I would agree
