Author Topic: Correct Alternator for 68 289  (Read 1511 times)
Offline janschutz
« on: July 14, 2011, 01:07:31 PM »
I looking for the correct alternator for my 68 coupe NJ built, 2/15/1968, 389 with C4.   The blow pictures are the alternator I took off back in the early 90s.  The stamping on it is 60A E276BA G26C.  Is that Correct?  If not What should I be looking for?
Offline Sunlitgold68
Re: Correct Alternator for 68 289
« Reply #1 on: July 14, 2011, 05:22:41 PM »
Is the word "motorcraft" embossed on the rear housing?
This page should show what you need. http://www.deadnutson.com/catalog/item/7070330/7161139.htm
8T01C204XXX
Built May 14th, 1968
Offline TLea
« Reply #2 on: July 14, 2011, 06:54:20 PM »
That is a later alternator. Motorcraft and stamped ID are dead giveaways. How is your car equipped? AC, extra cooling? All that determines what alt you should have.
Offline janschutz
« Reply #3 on: July 15, 2011, 10:31:01 AM »
Yes, That is the word Motorcraft.  Should it say Autolite?
It is 68 coupe NJ Built, 289, C4, AC, Am Radio, Deluxe interior, Fog Lights, Rear Trunk light (No under hood light but the original hood was missing)
Rear Window Defogger, 6K Tachometer and Clock, glove box light.
« Reply #4 on: July 15, 2011, 10:50:04 AM »
Yours is a later alternator that did not come on the car originally.
I also have a 68 NJ coupe built in May. The alternator I received from deadnutson.com did not have autolite on the back, although from what I understand, some did have the stamping.
8T01C204XXX
Offline janschutz
« Reply #5 on: July 15, 2011, 12:02:59 PM »
I just went to the deadnutson.com site and it did answer alot of questions.  Thanks.  I will be contacting them for an alternator.
