Author Topic: Power Brakes/Automatic Transmission  (Read 1202 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« on: July 12, 2011, 10:36:52 PM »
I have studied the Mannel Book.
Still need a picture of the vacuum port, tube, hoses, and fittings,
showing how it came if factory equipped with both options.
Mr. Mannel says "in 66, if equipped with AT/PB, a "special fitting" at the
PB booster is where the AT line attaches." ????
What special fitting?
66 Metuch Conv
Nightmist, Std Blu Int
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
Re: Power Brakes/Automatic Transmission
« Reply #1 on: July 12, 2011, 11:20:18 PM »
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
Offline bryancobb
  • 2009 Ridn' Around
« Reply #2 on: July 13, 2011, 08:34:27 AM »
Can I assume that those 3 pieces are the OEM assembly-line setup, including the tube?
That tube looks like the little one on page 6-32 in the Mannel book, but the other 2 brass parts do not look like the one on page 6-31.
Is the end of the tube tapered to a smaller diameter?
I'm also interested in seeing a picture of what it's suppose to look like after installation...where it points...what length hoses...what type clamps if any...routing?
« Last Edit: July 13, 2011, 10:27:27 AM by bryancobb »
66 Metuch Conv
« Reply #3 on: July 13, 2011, 10:00:20 AM »
Tube is aftermarket replacement, the brass is not. I did put the tape there. Look at Bobs book page 5-48.
This was one of many parts that was sitting loose in the engine bay, that is why I cleaned it up. The car is in storage but the loose parts got thrown into a box and taken to the house. It however it goes in where the AT line goes.
