Author Topic: Original Drive shaft  (Read 2514 times)
Offline Stangly
  • Gold Level Subscriber
« on: July 06, 2011, 02:01:14 PM »
Here are some photos of the drive shaft I removed from my car.  The original shaft was stolen from the car back in 1980 and was replaced by my father in-law with the one in the photos below.  Can anyone tell me if this  is in fact a drive shaft for a 69 mustang or from some other ford (cougar, falcon, etc).  It also has some bad dents in it that will need to be repaired so I would like verify if it is the correct one for the car before I spend any money restoring it.
Thank you,
David,
68 Coupe J-Code
2001 V6 Laser Red
2015 GT Deep Impact Blue
Re: Original Drive shaft
« Reply #1 on: July 06, 2011, 05:20:45 PM »
You mention that its for a 69 (that your looking for) but we need to know the application - automatic, 3 speed or 4 speed and what engine ?
The weights indicate that its an original that has not been reblanced or the tube replaced - just need to fingure out the application
Offline Stangly
« Reply #2 on: July 06, 2011, 07:50:32 PM »
Jeff,
Here is the missing information:
Engine-302 2-V
Transmission - automatic 3 speed (C4)
68 Coupe J-Code
2001 V6 Laser Red
« Reply #3 on: July 07, 2011, 09:56:00 PM »
Checked and did not have a clear picture of both ends on an original car.
I would have expected a tube in tube design for the automatic application but can not be sure. A white paint mark does not show up for your application.
All I have to offer at the moment - sorry
Offline Stangly
« Reply #4 on: July 07, 2011, 11:02:20 PM »
Jeff,
Thank you for taking the time to check.  My build sheet is really tough to read, I can't make out the last few color codes.  Is it typical that all 69 Dearborn 302 2V automatics would have the same color stripes?
David,
68 Coupe J-Code
2001 V6 Laser Red
Offline Stangly
« Reply #5 on: July 07, 2011, 11:21:29 PM »
Jeff,
I held the build sheet up to the light and the colors read as follows:
LBDGYL and the last blank (24) which is labeled code is B.  Not sure what all these colors translate to hopefully this may shed some light.  I would like to strangle the guy who stoled the original one.
David,
68 Coupe J-Code
2001 V6 Laser Red
« Reply #6 on: July 08, 2011, 01:07:37 AM »
That would decode out to Light Blue, Dark Green & Yellow
Offline Stangly
« Reply #7 on: July 08, 2011, 07:46:29 PM »
Thanks Jeff I really appreciate the help, have a good weekend.
68 Coupe J-Code
2001 V6 Laser Red
« Reply #8 on: July 09, 2011, 12:09:27 AM »
Thank is what the site is here for - have a safe weekend also
