Author Topic: Brake Parts & Fastner Finish ?  (Read 2078 times)
Offline 69 black r code
« on: July 05, 2011, 11:46:53 PM »
Need to verify finishes for following brake parts.
4-69 Metuchen
Front Brakes( Disc)
Brake Pad Inner & Outer Retainers   Phosphate & Oil
Brake Pad Inner Retainer Bolts   Phosphate & Oil
Brake Pad Outer Retainer Pins   Phosphate & Oil
Caliper Shield Bolts   Phosphate & Oil
Rear Brakes ( Drum )
Adjusters   Phosphate & Oil
Adjuster Lever   Zinc Chromate
Cable Guide   Zinc Chromate
Park Brake Lever   Bare Steel
Park Brake Link   Bare Steel
4-69 Mach1 NJ 428cj
Re: Brake Parts & Fastner Finish ?
« Reply #1 on: July 09, 2011, 12:16:59 PM »
4-69 Metuchen
Front Brakes( Disc)
Can anyone confirm that these finishes are correct?
4-69 Mach1 NJ 428cj
« Reply #2 on: July 09, 2011, 05:24:47 PM »
Front Brakes( Disc)
Brake Pad Inner & Outer Retainers   Phosphate & Oil-yes
Brake Pad Inner Retainer Bolts   Phosphate & Oil-yes
Brake Pad Outer Retainer Pins   Phosphate & Oil-yes
Caliper Shield Bolts   Phosphate & Oil- I have seen the special bolts in order of most often seen personal observation- zinc dicromate ,silver ,silver with safety red but not phosphate and oil-just me
Adjusters   Phosphate & Oil-yes
Adjuster Lever   Zinc Chromate-yes
Cable Guide   Zinc Chromate-yes
Park Brake Lever   Bare Steel-yes
Park Brake Link   Bare Steel-yes
« Reply #3 on: July 11, 2011, 01:58:04 AM »
Thanks for the help Bob !!
4-69 Mach1 NJ 428cj
