mine came up with the caulk stuck to the plug (on right) The one on the left is for shock plug. Might be because of "bite" it got to the steel or how I pried it off.You can see the old putty has turned a whiter/chalkie substance. Put back with this ,,,,,,,,,, it is too gray IMOMark
Jeff, you can use Rich instead of S Code. Fake galvanizing is zinc paint used to touch up galvanized fencing? If fence guy do any welding of the tubing then they are supposed to clean the area and use "cold applied galvanizing rich in zinc".
WOW! I tip my hat to you that's incredible. Very accurate looking. You were able to reproduce that on the opposite side as well in the cupped area?
Jeff so if I understand this correctly after plating spray grey and then immediately followed with silver and then while both are wet get going with the plastic baggie.
