Author Topic: 68 Gas Pedal with trim or not  (Read 2594 times)
Offline 68 S Code
« on: June 26, 2011, 02:01:58 AM »
Trying to figure out if my gas pedal should have the stainless trim rimg or not. Disc brake pad has trim. This is a standard interior convertible. Heard that the verts had a rubber boot on the high beam switch. Can anyone verify that?
Re: 68 Gas Pedal with trim or not
« Reply #1 on: June 26, 2011, 10:00:34 AM »
Yes, the verts had a rubber boot on the dimmer switch fastbacks did not. I have seen a number in personal observation and it is called out for in assemblyline manual.Bob
« Reply #2 on: June 26, 2011, 10:18:36 AM »
I do not think the brake or gas pedal should have the stainless trims with a standard  interior.
« Reply #3 on: June 26, 2011, 08:34:20 PM »
+1 on both responses
Offline 68 S Code
« Reply #4 on: June 26, 2011, 10:25:37 PM »
The brake pedal definately had "Disc Brakes" is a ss disc and a trim ring from what i remember. But what you both are saying is replace it with a plain rubber pad?
« Reply #5 on: June 26, 2011, 10:32:28 PM »
Didn't think that was the question ;) "Trying to figure out if my gas pedal should have the stainless trim rimg or not."
Believe everyone was responding to the question about the trim ring no what the pad design was
Offline Andrew@MagMustangs
    • MagMustangs
« Reply #6 on: June 27, 2011, 12:47:22 AM »
The Books say 'Bright Pedal Trim' was for Interior Decor in 1968.
Offline 68 S Code
« Reply #7 on: June 27, 2011, 09:22:05 AM »
So the way I understand it no bright metal trim on either gas or brake pedals. Sounds like brake pedal may have the center disc with wording?
« Reply #8 on: June 27, 2011, 11:31:42 AM »
If the car had factory disc brakes, then it would definitely have the center "DISC BRAKE" circular stainless insert.  Has nothing to do with the trim around the perimeter.
Offline 68 S Code
« Reply #9 on: June 27, 2011, 12:09:48 PM »
Got it. Thanks Murf.
Offline 68 S Code
« Reply #10 on: June 27, 2011, 09:43:27 PM »
I was looking for the floor pan drain plugs and saw the brake pedal pad. Found original brake and gas pad trims. Maybe they are from the old fastback GT?
